How Do You Calculate Rocket Exhaust Velocity and Total Acceleration at Liftoff?
  • Thread starter Thread starter AbigailM
    Rocket
The discussion focuses on calculating the rocket exhaust velocity and total acceleration at liftoff for the Saturn V rocket. The liftoff thrust is specified at 34 × 106 N with a specific impulse of 2580 N-s/kg and an initial mass of 3.0 × 106 kg. The correct exhaust velocity is determined to be 2580 m/s, which corresponds to a specific impulse of 263 s. The total acceleration felt by astronauts at liftoff, accounting for gravity, is calculated to be approximately 1.15 g's, aligning closely with experimental data of 1.13 g's.
  • Understanding of specific impulse and its relation to exhaust velocity.
  • Knowledge of Newton's laws of motion, particularly the third law.
  • Familiarity with rocket thrust equations and mass flow rate calculations.
  • Basic grasp of gravitational acceleration and its impact on total acceleration.
  • Study the derivation of rocket thrust equations and their applications in aerospace engineering.
  • Learn about the principles of specific impulse and its significance in rocket propulsion.
  • Explore the effects of gravity on spacecraft acceleration during liftoff.
  • Investigate experimental methods for measuring rocket performance metrics, including thrust and acceleration.
Aerospace engineers, physics students, and anyone interested in rocket propulsion and performance calculations will benefit from this discussion.
AbigailM
Still preparing for a classical prelim. Not sure if my solution is correct. Any help is more than appreciated.
According to specifications, the five Saturn V booster engines collectively supplied a liftoff thrust of [itex]34 \times10^{6}N[/itex]. The specific impulse was 2580 N-s/kg. The initial mass of the rocket was [itex]3.0\times 10^{6}kg[/itex]. Given these specifications, what was the exhaust velocity, and what was the total acceleration including the acceleration of gravity, felt by the astronauts on liftoff (in g's)?
*The specific impulse is the ratio of the thrust to the rate of consumption of propellant. It is nearly constant.
[itex]v_{ex}=I_{sp}g \hspace{5 mm}\dot{m}=\frac{F_{th}}{I_{sp}}[/itex]
[itex]a(t)=\frac{\dot{m}v_{ex}}{m_{0}-\dot{m}t}-g=\frac{F_{th}g}{m_{0}-\dot{m}t}-g[/itex]
where [itex]m(t)=m_{0}-\dot{m}t \hspace{5 mm}m(t)a(t)=\dot{m}v_{ex}[/itex]
[itex]\dot{m}=\frac{3400\times 10^{4}N}{2580\frac{N.s}{kg}}=1.3\times 10^{4}\frac{kg}{s}[/itex]
[itex]a(t)=\frac{3400\times 10^{4}N}{3.0\times 10^{6}-1.3\times10^{4}\frac{kg}{s}t}g -g[/itex]
Note: Something that confused me was that that the [itex]I_{sp}[/itex] given is in m/s.
Thanks for the help.
When specific impulse is given in unit m/s (which is equal to N-s/kg) it really represent exhaust velocity, as related by your first equation. That is, the exhaust velocity of 2580 m/s corresponds to a specific impulse of 263 s.
Notice, that your second equation is not correct (it misses a "g", or, you should replace Isp with Vex). However, since you actually used Vex in your calculation you ended up with the correct result for the mass rate.
The expression for the rockets acceleration looks correct, but if you want a(t) to represent how much acceleration the astronauts feel (including gravity) you want consider what a(t) should be equal if the rocket has zero acceleration. Also, as I read the last question, it seems you only need to calculate the value of a(0), that is, the felt acceleration at lift-off.
As always Filip thanks for the help.
Yep it does say a(0) lol, hope I don't miss something like that on an exam.
There ended up being an error in my a(t) equation, because I should have used [itex]v_{ex}=I_{sp}\frac{g}{g}[/itex]. When I use that and crunch out the liftoff acceleration ignoring gravity, I get roughly 1.15g's, which is close to the 1.13g's experimental.
And thanks for the gravity hint, I should have put + instead of -. The acceleration vector on the crew is in the same direction as gravity, even though the rocket's acceleration vector is upwards. Newton's third law :(.
  • · Replies 42 ·
