| New Reply |
Point of application of magnetic torque. |
Share Thread | Thread Tools |
| Jul3-12, 02:41 PM | #1 |
Hello, When a current carrying loop (of any shape) is placed in a uniform magnetic field B , the field is given by MχB where M is the magnetic moment vector I*A where I Is current and A is the area vector. I want to know at which point or for which axis is the torque applied given by the above equation. 2. Relevant equations ζ=MχB M=I*A 3. The attempt at a solution |
| Jul3-12, 05:52 PM | #2 |
hi anmol21! welcome to pf!
![]() if B is uniform, the resultant force will be zero, so the effect is a pure torque so the circuit will turn about the centre of mass of whatever the circuit is fixed to (or about whatever axis that is constrained to turn around) |
| Jul4-12, 04:45 AM | #3 |
Thanks tiny-tim :)
So is the magnetic torque independent of the axis chosen ? For example , Consider a sphere with a ring attached to it , with current I in the ring , in rotational equilibrium on a rough inclined plane. The magnetic field is vertically downwards and gravity is present. So we can equate the torque due to gravity and the magnetic torque at any point . So will be the magnetic torque be same even at the point of contact of the sphere with the ground or the centre of the sphere ? |
| Jul4-12, 04:57 AM | #4 |
hi anmol21!
![]() the magnetic torque of a uniform magnetic field on a circuit is a couple … it is exactly the same as a couple (or "pure moment") in mechanics: it has the same moment about any point "a system of forces with a resultant (a.k.a. net, or sum) moment but no resultant force"both quotes from http://en.wikipedia.org/wiki/Couple_(mechanics)
| Jul5-12, 05:18 AM | #5 |
thanks a lot , that clears it up :)
| New Reply |
| Tags |
| couple, magnetic field, magnetic moment ., torque |
| Thread Tools | |
Similar Threads for: Point of application of magnetic torque.
| Torque application. | General Engineering | 5 | ||
| magnetic torque acts about which point on magnetic dipole? | Classical Physics | 1 | ||
| Does application of torque add to rotational stability? | General Physics | 1 | ||
| Dynamic application of torque with center of mass... | Introductory Physics Homework | 7 | ||
