| New Reply |
which string cutten? (impulse) |
Share Thread | Thread Tools |
| Jul4-12, 04:39 AM | #1 |
suppose a metal ball is hanging by a string and there is another string is hanging at buttom of the ball if you pull buttom string very fast which of strings (up and buttom) will be cutten ?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jul4-12, 04:45 AM | #2 |
There are too many undefined parameters in your question. Method of attachment is one example thereof. I admit that I don't really have a clue about this, but it seems to me that even the lengths of the string segments would be relevant. (The longer the string is, the more likely it is to break.)
| Jul4-12, 04:49 AM | #3 |
i know the answer, but i dont why. if you pull very fast(impulse) the buttom string cutten and if you pull slowly(static) the upper cut, but why?
| Jul4-12, 04:58 AM | #4 |
Have you repeated this experiment often enough to be sure that the results are guaranteed? If so, will you please describe the set-up in more detail? I'm not disputing your conclusion; I just don't know exactly how you arrived at it.
| Jul4-12, 06:35 AM | #5 |
Recognitions:
It is a very good demonstration, persia7. |
| Jul4-12, 08:19 AM | #6 |
Initially the stress & strain is higher in the upper string as there is no load on the lower one.
If an impulse load is applied to the lower string then the inertia of the metal ball causes a delay between the rising stress in the lower string and rising stress in the upper string. If the impulse is short but large enough the strain in the bottom string will reach breaking point before the top. So lower string breakes first. If the load is applied slowly then the strain increases at the same _rate_ in both strings BUT the top string had a head start so it reaches breaking point first. Upper string breakes first. |
| Jul4-12, 11:23 AM | #7 |
i agree with CWatters , but can you explain with formula what happen when impulse load applied on lower string?
| Jul4-12, 11:38 AM | #8 |
| Jul4-12, 11:43 AM | #9 |
please explain with momentum or ... formula(mathematical)
| Jul4-12, 12:15 PM | #10 |
The length and modulus of the strings (identical material, I assume) will affect the result, as well as the 'speed' and force applied. A helpful model would be to treat the strings as springs and the Spring - mass - spring - support would have different natural modes of oscillation. I don't think the calculations would be that hard to do (you'd need a bit of motivation). First write an equation of motion and solve it for the conditions. In the end, it's coupled oscillators. For a slowly applied force, the result will always be that the top string will break, of course.
| Jul5-12, 12:57 PM | #11 |
can you tell me a book help me?
| Jul5-12, 01:24 PM | #12 |
| New Reply |
| Thread Tools | |
Similar Threads for: which string cutten? (impulse)
| Finding Impulse Transfer Function with Impulse Invariant Method | Engineering, Comp Sci, & Technology Homework | 1 | ||
| tension of string when an impulse is applied | Introductory Physics Homework | 6 | ||
| Does String Field Theory have the potential to outshine the regular string theories? | Beyond the Standard Model | 2 | ||
| [SOLVED] [String-schools] String Vacuum in Trieste 2006 | Beyond the Standard Model | 0 | ||
| Introductory Interactive Online String Theory Seminar at the String Coffee Table | Beyond the Standard Model | 0 | ||
