| Thread Closed |
Venus Spinning Slower Than Thought |
Share Thread | Thread Tools |
| Jul4-12, 11:05 AM | #1 |
Apparantly this one was missed, at least nothing turned up on a search.
But then again, a long time ago, when thinking out the box was still allowed, there was a thread speculating about how Venus could have lost its spinning and what happened to the related energy. For those who are familiar with that, there is no reason at all to be 'stumped'. |
| Jul4-12, 03:00 PM | #2 |
It's more likely the outer crust has been migrating over the molten interior.
I've read something in that article about the features on the surface being 20 km from where they should be. A 20 km migration of the crust doesn't seem that much to me, considering Venus' volcanic past, with a lot of its surface covered with lava. |
| Jul4-12, 04:09 PM | #3 |
Here is some study material: http://www.imcce.fr/Equipes/ASD/prep...enus1.2002.pdf http://www.gps.caltech.edu/classes/g...ansen_1998.pdf |
| Jul4-12, 04:22 PM | #4 |
The best theory I can remember for the rotation of Venus is that the planet was hit by another proto-planet in the distant past, close to the time the solar system was created.
Such impacts are also attributed for the the creation of Earth's Moon, for an extremely large crater on Mars which covers most of Mars' north side, for the peculiar inclination of Uranus, and maybe other examples. As for the current observed slowing down, I don't believe it is possible to slow down an entire planet. You can however slow down the movement of it's outer crust. Whether it's the atmosphere doing this, or some other phenomenon, that's a matter for research. |
| Jul4-12, 06:56 PM | #5 |
First air pollution, light pollution and noise pollution - now they've invented celestial mechanical pollution! |
| Jul4-12, 07:32 PM | #6 |
| Jul4-12, 08:05 PM | #7 |
| Jul5-12, 01:32 AM | #8 |
| Jul5-12, 03:23 AM | #9 |
If Venus has a rather thin crust over a molten layer, that crust can shift under the influence of the atmosphere.
The thinner the crust, the bigger this effect can be. Atmospheric weather and earthquakes only affect the movement of the crust, not of the entire planet. Tidal forces slow down the entire planet, but this effect is very very slow. |
| Jul5-12, 05:51 AM | #10 |
| Jul5-12, 07:05 AM | #11 |
Mentor
Venus' atmosphere is very weird. Venus as a planet rotates very slowly, once per 243 days, and retrograde with respect to the solar system's angular momentum. Venus' upper atmosphere rotates very quickly, once every four days, and posigrade with respect to the solar system's angular momentum (so retrograde with respect to Venus).
One obvious (and probably the most obvious) explanation is that there must be some unexplained decades-long variations in Venus' atmosphere that result in transfer of angular momentum between Venus proper and it's atmosphere. The problem is the mechanism. Scientists do not know, and this site is not the place to be making speculations. We do see this transfer of angular momentum between planet and atmosphere right here on the Earth. The Earth's rotational rate varies with the seasons (the Earth slows down a tiny bit in January and February, then speeds up again), and it turns out that the atmosphere is the key cause. We also see decadal variations in the Earth's rotation rate. Those variations remain an unexplained mystery, at least to some extent. There are too many possible culprits, too little data to narrow down the cause. We have millions and millions of measurements for the Earth and yet the Earth's rotation is not a fully solved problem. We have orders of magnitude fewer measurements of Venus. Is it any surprise that Venus' rotation is not a fully solved problem? |
| Jul5-12, 07:08 AM | #12 |
I must say, I'm rather befuddled that claims of the day having slowed down were made by observing a 0.00186% error in an extrapolation from 20 year old data rather than, y'know, re-measuring the rotation of Venus. Amusingly, the error in the length of the Venusian day between the two articles is nearly as large as the reported error of 6.5 minutes. IMO the fact we haven't heard anything again is far more likely to be publication bias than anything else: that the announcement was made prematurely, and nobody thought it was worth publishing a retraction. Or, it is true but uninteresting, and the fact it was even mentioned in the first place is an anomaly. |
| Jul5-12, 07:32 AM | #13 |
Mentor
| Jul5-12, 10:14 AM | #14 |
I've seen no evidence for "Venus has a thick crust over a solid mantle". Do you have a reference for that ? You're obviously not an expert on this subject, but as you're a moderator you give infractions and your words on a subject your knowledge seems limited on, are supposed to carry weight. |
| Jul5-12, 10:27 AM | #15 |
About the data, the article states:
However Furthermore it's interesting to understand how the accuracy in astronomy and space exploration can decay over time, when far before Magellan, success or failure depended on many more digits accuracy. |
| Jul5-12, 07:29 PM | #16 |
But it's interesting to note that web searching for the figure already shows much greater error than that. The two articles you linked show 243.015 and 243.0185. Wikipedia reports the latter. NASA's page on Venus says 243.018, and also reports the figure in hours: 5832.4 -- a figure with listed precision three digits less than yours! I could not find any references that have error bounds on this figure. Incidentally, your post is the only Google hit for "243.01865 venus". |
| Jul5-12, 08:11 PM | #17 |
Mentor
That said, that's a bad assumption. You need to look deeper if you aren't given further details and you need those details. You might have just gotten lucky with that assumption of a 9 second error. The scientific literature is always a good place to look deeper. "A rotation period estimate of 243.0185 ± 0.0001 days was determined via the ephemeris improvement technique applied simultaneously to two overlapping orbit blocks with many common points and separated by two full Venus rotations." |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Venus Spinning Slower Than Thought
| If a spinning top is is spinning in place is the spinning top moving? | General Physics | 2 | ||
| Whose clock is really slower? | Special & General Relativity | 149 | ||
| Which clock is slower? | Special & General Relativity | 96 | ||
