An Inquiry as to the Higgs Boson's Mass
  • Context: Graduate
  • Thread starter Thread starter gsmith
    Higgs Mass
The Higgs boson has a mass of approximately 125 GeV, determined through experiments at the Large Hadron Collider (LHC). The mass arises from the Higgs particle's interaction with itself, as outlined in the Standard Model of particle physics. The Higgs mass is classified as a "free parameter," meaning it can theoretically take on a wide range of values, but experimental data has narrowed it down to around 125 GeV. This discrepancy between theoretical predictions and experimental findings presents an ongoing puzzle in particle physics.
  • Understanding of the Standard Model of particle physics
  • Familiarity with the concept of mass generation via the Higgs field
  • Knowledge of particle interactions and self-interactions
  • Experience with experimental physics, particularly in high-energy particle collisions
  • Research the implications of the Higgs boson's mass on the Standard Model
  • Explore the experimental methods used by the LHC to measure particle masses
  • Investigate the concept of free parameters in theoretical physics
  • Learn about the ongoing searches for physics beyond the Standard Model
Physicists, researchers in particle physics, and students studying the Standard Model and Higgs boson properties will benefit from this discussion.
gsmith
The Higgs particle has a mass of about 125 GeV. If interaction with the higgs field assigns a particle its mass, how does the Higgs field assign itself mass?
By interacting with the Higgs :D. In addition, the particle has a mass on its own.
Both contributions are relevant, and it is quite interesting (and a puzzle for the theory) that the difference of those is as small as 125GeV, as both parts are assumed to be many orders of magnitude larger.
The Higgs boson's mass arises in the standard model from the Higgs's interaction with itself.
Are you asking how it picks the value 125 GeV? This the standard model does not predict. The Higgs mass is a "free parameter"--you can pick any value from for it you want from a large range and still get a mathematically consistent theory. So you have to determine by experiment which mass Nature chose. That's why the LHC experiments had to initially search for the Higgs over a large range of masses before eventually zeroing in on the region around 125 GeV.
  • · Replies 17 ·
