Sphere rolling in a semisphere
  • Context: Graduate
  • Thread starter Thread starter ShayanJ
    Rolling Sphere
The discussion focuses on the dynamics of a sphere rolling within a semicircle, characterized by the Lagrangian formulation. The Lagrangian is defined as L = m(1/2 R² ẋ² + 1/5 r² ẋ²) - mgR(1 - cos(α)), leading to equations of motion for angles α and β. The analysis reveals that assuming pure rolling leads to a contradiction, suggesting that the angles α and β are not independent. The correct approach involves applying the rolling constraint before deriving the equations of motion, resulting in the equation (7/5)R² α'' = -gR sin(α).
  • Understanding of Lagrangian mechanics
  • Familiarity with rolling motion dynamics
  • Knowledge of differential equations
  • Concept of constraints in mechanical systems
  • Study the application of Lagrangian mechanics in constrained systems
  • Learn about rolling motion and its constraints in classical mechanics
  • Explore the derivation of equations of motion using Euler-Lagrange equations
  • Investigate the implications of quantization in mechanical systems
Physics students, mechanical engineers, and researchers interested in classical mechanics and the dynamics of rolling bodies.
ShayanJ
Insights Author
Consider a sphere and a semicircle with radii r and R respectively.(R>>r)
The sphere has mass m.Imagine we place it in the semicircle and let it rotate in it.
Let's take the z axis the line which passing through the center of the semicircle and the bottom of the semicircle with the origin at the center of the semicircle.
Now we write the Lagrangian with coordinates [itex]\alpha[/itex] and [itex]\beta[/itex].
[itex]\alpha[/itex] is the angle that the radius passing the sphere makes with the z axis and [itex]\beta[/itex] is the angle which shows the rotation of the sphere around its axis.
[itex] L=m(\frac{1}{2} R^2 \dot{\alpha}^2+\frac{1}{5} r^2 \dot{\beta}^2)-mgR (1-\cos{\alpha})[/itex]
With this Lagrangian,the equations of motion become
[itex] \ddot{\alpha}-\frac{g}{R} \sin{\alpha}=0[/itex]
[itex] \frac{2}{5} m r^2 \dot{\beta}=constant=h[/itex]
Also we assume that the sphere is pure rolling so
[itex] v_{cm}=R\dot{\alpha}=r\dot{\beta}[/itex]
Solving for [itex]\dot{\beta}[/itex] and putting it in the second equation we get
[itex] \frac{2}{5}mr^2\frac{R}{r}\dot{\alpha}=h \rightarrow \frac{2}{5} m r R \dot{\alpha}=h[/itex]
Solving the above equation for [itex]\dot{\alpha}[/itex], we have
[itex] \dot{\alpha}=\frac{5h}{2mrR}[/itex]
But this means that [itex]\dot{\alpha}[/itex] is constant which means [itex]\ddot{\alpha}[/itex] is zero.Taking this and the differential equation of motion for [itex]\alpha[/itex] we get
[itex] -\frac{g}{R}\sin{\alpha}=0[/itex]
Which means that [itex]\alpha=k\pi[/itex]!This seems to be a quantization which is completely nonsense.
Does this mean that in such a condition,pure roll is impossible?
If not,what's wrong?
Thanks
You cannot extract your equations of motion like this, if alpha and beta are not independent. Use your rolling constraint first and let the Lagrangian be a function of alpha only. This will give you a proper equation of motion.
I agree with mfb. You need to put the constraints in before calculating the Euler-Lagrange equations. You should get [itex]\frac{7}{5}R^2 \alpha'' = -g R sin(\alpha)[/itex]
  • · Replies 30 ·
  • · Replies 59 ·
  • · Replies 16 ·
  • · Replies 0 ·
