Finding the Limit of (3x^2 + ax + a + 3) / (x^2 + x - 2) as x Approaches -2
  • Thread starter Thread starter KiwiKid
    Limit
The problem involves finding a value for 'a' in the expression (3x^2 + ax + a + 3) / (x^2 + x - 2) such that the limit exists as x approaches -2. The subject area pertains to limits and algebraic manipulation in calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the requirement for the numerator to equal zero at x = -2 to avoid an undefined limit, leading to questions about the necessary conditions for 'a'. Some suggest using L'Hopital's Rule or factoring to find a suitable form for the numerator.
The discussion is active, with participants exploring different approaches to determine the conditions under which the limit exists. Some guidance has been provided regarding the need for the numerator to also approach zero as x approaches -2, and there is a general agreement on the direction of the reasoning, though no final consensus has been reached.
Participants note the inherent challenge of the problem, particularly the requirement that the denominator approaches zero at x = -2, which complicates the limit evaluation. There is an emphasis on finding a suitable value for 'a' without providing a complete solution.
KiwiKid
Is there a number 'a' such that
exists as x goes to -2? If so, find the value(s) of 'a' and the limit.
The limit rules. Algebra.
Well... I have absolutely no clue what I'm supposed to do. I suppose I'll have to choose my 'a' values in such a way so the denominator no longer equals zero, *but* other than brute-forcing a-integers in a graphical calculator I have little idea on how to do that.
I began by factoring the denominator to (x+2)(x-1), with the hope that I may be able to negate the x+2 somehow, but that didn't work. Then I tried to get (x^2+x-2) in the numerator so the numerator and denominator would cancel out and leave a bit on top, but I couldn't find a way to do that, either.
Could someone give me a clue on what approach to try here?
The denominator always goes to 0 if x goes to -2. What should the numerator go to if the limit were defined?? For example, if the numerator were 1, then the limit would be "1/0" which would be an infinity and thus the limit would not exist.
Is there a value for the numerator for which the limit does exist?
Have you heard of L'Hopital's Rule? It should work here. If not, note that the numerator must also go to 0 as x goes to -2, and must therefore have a factor of x+2.
Are you saying that the numerator should equal 0?
Yes! If x=-2, then the numerator should be 0.
Ok, let me see if I got this right:
3(-2)^2+a(-2)+a+3 = 0
-> 12 - 2a + a + 3 = 0
-> a = 15
Therefore (substituting a):
lim[x->-2] (3x^2 + 15x + 18) / (x^2 + x - 2)
= lim[x->-2] (3(x+2)(x+3)) / ((x+2)(x-1))
= lim[x->-2] (3(x+3)) / (x-1)
= 3 / -3
= -1
I think I got it. Thanks again! :smile:
-> a = 15
= 3 / -3
= -1
That looks good.
  • · Replies 26 ·
  • · Replies 44 ·
