OUNT OF CHARGE IS NOT CONSERVED!
  • Thread starter Thread starter CinderBlockFist
    Charges
The discussion revolves around the electrostatic interactions between three identical conducting spheres, focusing on charge distribution and the resulting forces after contact. The problem involves understanding how charge conservation and distribution affect the electrostatic force between the spheres.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the effects of charge distribution when the spheres come into contact, questioning the assumptions about charge conservation and the resulting forces. Some participants attempt to calculate the final charges and forces based on their interpretations of the interactions.
There are multiple interpretations of how the charges distribute among the spheres after contact. Some participants have provided calculations and reasoning, while others are questioning the correctness of these approaches. The discussion is ongoing, with no clear consensus reached on the correct methodology or final answer.
Participants are grappling with the implications of charge conservation and the equal potential of identical spheres, which may lead to confusion regarding the final charge values and the corresponding electrostatic forces.
CinderBlockFist
Identical isolated conducting spheres 1 and 2 have equal amounts of charge and are separated by a distance large compared with their diameters (Fig. 22-20a). The electrostatic force acting on sphere 2 due to sphere 1 is F. Suppose now that a third identical sphere 3, having an insulating handle and initially neutral, is touched first to sphere 1 (Fig. 22-20b), then to sphere 2 (Fig. 22-20c), and finally removed (Fig. 22-20d).
In terms of F, what is the electrostatic force F' that now acts on sphere 2?
The way I did it, when Sphere1 touches Sphere3, they both end up w/ electrostatic force of 1/2F. Then when Sphere3 touches Sphere2, they distribute evenly to have a electrostatic force of 0.75 F.
But this answer is wrong, what did i do wrong?
Use the expression of Coulomb force and take into account that,due to equal potential,the spheres that come into contact have the same charge...
Daniel.
Be careful about the sign of the charges. A +1/2 F charge on sphere 3 and -1F charge on 2 gives a net -1/2 F shared between 2 and 3.
AM
OH crap, thanks mason, leme try it out.
OK, first i had particle1 had -1 charge, and neutral particle 3 had +0.5, and -0.5 charge (since it is the same size as particle 1). When they touch, I added up the charges and divided by two, since the charges would distribute equally, so both end up w/ -0.75 and +0.25 charge.
Next, particle 3 touches 2, so i get net of -0.75, and +1.25, dividing by 2, I get +0.625 and -0.375, for a total net charge of +0.25 for particles 2 and 3.
Why is this answer wrong?
My final 2 answers available are 0.5 and 0.375
Just worry about the - charge. + charge is a deficit or lack of - charge.
Sphere 1 has charge -1. S3 has 0 charge. When s3 touches it, charges flow so that the electrical potentials are equal. Since they are identical spheres, this means that each sphere has the same charge. So s3 and s1 each have -1/2 charge. The same thing happens when s3 touches s2. The net charge (+1/2) is distributed equally between s2 and s3 so each charge ends up with +.25.
So you end up with s1 having -.5 charge and s2 having a + .25. Since the coulomb force is proportional to the product of the charges, the new force will be: F' = .125 F
AM
  • · Replies 26 ·
13K
  • · Replies 50 ·
  • · Replies 18 ·
