Solving Sin (90+Theta) = Cos - Explanation
In summary, the conversation is discussing the trigonometric identities for sine and cosine, specifically focusing on the equations sin(90-theta) = cos theta and sin(90+theta) = cos theta. The conversation also touches on the definition of sine and cosine, the use of radians, and the importance of using supplementary angles in trigonometric calculations.
sambarbarian
68
i understand how sin90-theta is cos , but i am having trouble with sin 90+theta = cos ...please explain
Mathematics news on Phys.org
I'm not clear what you are asking. The left side of each equation, sin(90- theta), and sin(90+ theta) make sense but the right side "cos" is meaningless. Do you mean cos(theta)?
What definition of sine and cosine are you using? If you are using the basic trigonometry definitions, then if one angle in a triangle is theta, the other is 90- theta so that "near side" and "opposite side" are reversed so that "sine" an "cosine" are switched. But in that case "sin(90+ theta)" makes no sense. A right triangle cannot have an angle larger than 90 degrees.
In Calculus, we need sine and cosine functions for all x and so use more general definitions. One common one is this:
Draw the unit circle on a coordinate system ("the unit circle" has center at (0, 0) and radius 1). Given positive number t, measure around the circumference of the circle counter-clockwise (for negative t, clockwise). The coordinates of the terminal point are, by definition, (cos(t), sin(t)). "By definition" here means the definition of sine and cosine- whatever those coordinates are, we define cos(x) and sin(x) to be those values)
Of course, to get "sin(90)= 1" and "cos(90)= 0" we have to interpret "t" in radians. The unit circle has circumference [itex]2\pi[/itex] so that 1/4 of the way around, from (1, 0) to (0, 1) is [itex]2\pi/4= \pi/2[/itex] radians which is equivalent to 90 degrees.
Now, notice that the points on the unit circle corresponding to central angles 90- theta and 90+ theta (distances along the circumference [itex]\pi/2- x[/itex] and [itex]\pi/2+ x[/itex] with x in radians) are symmetric about the y-axis. They have the same y coordinate, and their x coordinates differ only in sign. Thus [itex]sin(x+ \pi//2)= sin(x- \pi/2)[/itex] where x is in radians or [itex]sin(90+ \theta)= sin(90- \theta)[/itex] with [itex]\theta[/itex] in degrees.
yes i meant cos theta
im using the basic trig identities ... in my textbook we have a table which denotes ...
sin(90-theta) = cos heta
sin(180-theta) = sin theta
sin(180+theta) = - sin
and so on..
i was also confused because trig is applicable only in right angles ... i can't make sense of any except the first .
Hello Sam,
Firstly to echo what Halls of Ivy said,
The angle theta can be as large as we like.
I'm sure you know that there are 360 degrees in a whole circle 720 in two circles etc.
For every whole circle we wind round we take off 360 degrees.
So 750 degrees is equivlent to 750 -360-360 =30 deggrees
By equivalent to I mean that if you wind a clock hand round 750 degrees or 30 degrees it will end up in the same place.
So it is reasonable to think that the values of trig functions for 750 will be the same as those for 30.
This is indeed true.
The only other thing to understand is that we must agree which way to wind the clock handle and where from.
In mathematics we start from the positive x-axis and wind anticlockwise.
That is the convention.
To look more closely at this look now at my sketches.
The first shows the clock hand winding round from the x-axis an angle theta.
This hand also creates two triangles with the x axes and I have written out the sin and cos for both triangles.
This shows the relationship between theta and (90 - theta)
The second sketch shows what happens with 180 - theta.
Can you form the triangles for yourself here?
Remember that y is still positive, but x is now negative.
The second attachment shows what happens when you use all four quadrants.
Some of the trig quantities are negative and some positive in any quadrant, but there is always one positive in any quadrant.
I have worked out the tangent in this instance.
Can you do the sin and cos now?
Likes Monsterboy
hey Studiot , thank you for your reply , it solved most of my difficulties but i still have a confusion
in first quadrant , we get cos theta = x/underoot x^2 + y^2
but then if we do it for 90+theta .. my value for sin (90 + theta) is -x/underoot x^2 + y^2
which is basically our previous value of cos theta * (-)therefore sin 90 + theta should be equal to - cos theta , not cos theta
Yes, that is true. "[itex]cos(\theta)[/itex]" is the x-component of the [itex](cos(\theta), sin(\theta))[/itex] and so is negative as we move from first quadrant to second quadrant.
However [itex]sin(\theta)[/itex] is the y component and does NOT change sign. That is, if [itex]0<\theta< 90[/itex], in the first quadrant, [itex]\theta+ 90[/itex] is in the second quadrant. [itex]sin(\theta+ 90)[/itex] is still positive as is [itex]cos(\theta)[/itex].
Hello again Sam.
Supplementary angles add to 180
Complementary angles add to 90
Complementary angles are more tricky since you have to exchange x and y or sin and cos in the formulae to get the correct triangle.
Sin is still OHMS and cos is still AHMS however.
You do not do this with supplementary angles.
To see why look at the attachment.
The first quadrant triangle with angle theta is shown as OAB.
I have generated a line OD in the second quadrant by adding 90 to theta.
However the triangle you want is not ODC.
The triangle you want is ODE as shown.
Using this triangle the attachment shows that
cos(90 + θ) = -sin(θ)
You should always use supplementary angles where possible for this reason.
go well
ty studiot , i understod itt now , btw if u don't mind me asking , how was my logic wrong ? the one which proved sin 90+theta = - cos theta
and so on..
If you don't mind, can you post the full table? I would like to memorize these but can't find these on the internet. Thx
You used the wrong triangle. That's why I said complementary angles are more tricky.
It's in the last attachment x/√(x2+y2) is for triangle ODC
I do not see why we are having such diffuculty.
From the angle sum formulae of the sine function, we obtain
[tex]\sin(\pi/2 + \theta) = \sin(\pi/2)\cos(\theta) + \cos(\pi/2)\sin(\theta) = \cos(\theta)[/tex]
since [itex]\sin(\pi/2)=1[/itex] and [itex]\cos(\pi/2)=0[/itex].
i wanted to prove it logically
Sam I owe you an apology, there was an error in my post7, so well spotted.
I tried this morning but couldn't amend it however I will supply a correction later tonight.
OK I promised an ammendment.
You notices that I had written sin(90+θ) instead of sin(90-θ).
In fact it makes no difference they are the same.
However since this was an unintentional slip and I should have used sin(90-θ) here is a geometric proof that
cos(90+θ) = -sin(θ)
in attachment 1.
Since is is some effort I will leave you to construct similar proofs for sin and tan.
It is really much easier to use Millenial's method for this and I have shown all three in attachment 2
go well
What is the equation "Solving Sin (90+Theta) = Cos - Explanation"?
The equation "Solving Sin (90+Theta) = Cos - Explanation" is a trigonometric equation that involves solving for the variable Theta.
What is the purpose of solving this equation?
The purpose of solving this equation is to find the value of Theta that satisfies the equation and represents a solution to a given problem.
What is the process for solving this equation?
The process for solving this equation involves using trigonometric identities and algebraic manipulation to simplify the equation and isolate the variable Theta on one side of the equation.
Are there any special cases or restrictions when solving this equation?
Yes, there are a few special cases and restrictions to keep in mind when solving this equation. These include making sure the values of Theta and the trigonometric functions are within their respective domains, and being aware of any identities that may need to be used in the process.
How can I check if my solution is correct?
You can check if your solution is correct by plugging your answer back into the original equation and seeing if it satisfies the equation. You can also graph the equation and your solution to visually confirm if they intersect at the given point.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
