How much will pipe weigh in a well
  • Thread starter Thread starter helpmitch
    Pipe
The discussion centers on calculating the weight of a pipe submerged in a closed cylinder filled with water, while applying compressed air from the top. Key considerations include accounting for the fluid weight inside the pipe and the upward force exerted on the pipe due to external pressure. The user seeks to determine the burst pressure of the pipe by analyzing the pressure differential between the inside and outside. A suggested starting point is calculating the cubic displacement of the pipe to find the fluid weight.
  • Understanding of fluid mechanics principles
  • Knowledge of pressure differentials and buoyancy
  • Familiarity with pipe burst pressure calculations
  • Basic skills in volume and weight calculations
  • Research fluid mechanics, focusing on buoyancy and pressure differentials
  • Learn how to calculate pipe burst pressure using the formula for hoop stress
  • Explore methods for calculating cubic displacement of cylindrical objects
  • Investigate the effects of compressible fluids on pressure calculations
Engineers, physicists, and anyone involved in fluid dynamics or pipe design will benefit from this discussion, particularly those interested in pressure calculations and material strength assessments.
helpmitch
I want to know how much a piece of pipe would weigh if I ran it down into a cylinder that was closed off at both ends except for a place to run the pipe through and a port to pump compressed air at the top. The cylinder would have water in it and I would apply air pressure through the top to push water down the cylinder and out the pipe. The problem is I don’t know how to calculate what the pipe would way during this process. Since the pressure outside the pipe would have to be greater than in the pipe would I have to account for the fluid weight in the pipe and would there be an upward force applied to the pipe. Also how do I calculate a what point the pipe would burst, I am thinking that since the out side pressure of the pipe is just a few pounds greater than that of the inside pipe that I could use that difference for my burst rating. Any help would be greatly appreciated and I my apologies for my lack of terminology.
I think you just need to calculate the cubic displacement of the pipe, then find out the fluid weight.
That could be a starting point, anyways.
  • · Replies 37 ·
  • · Replies 31 ·
  • · Replies 20 ·
12K
