Circuit Potential and Voltage Calculations
  • Thread starter Thread starter triplezero24
    Circuit Couple
The discussion revolves around calculating electrical potential and voltage in a circuit involving capacitors and a battery. The original poster expresses confusion regarding the calculations needed for a specific point in the circuit.
  • Participants discuss the need to find the equivalent capacitance of capacitors in series and the total charge. There is also a focus on the concept of absolute potential versus potential difference, with questions raised about the grounding of the circuit.
Some participants have offered guidance on finding the total capacitance and charge, while others are exploring the implications of grounding in the circuit. Multiple interpretations of the problem are being considered, particularly regarding the calculation of potential at point D.
There is a mention of a grounding point at A (V=0), which is crucial for determining potential. Additionally, issues with accessing the circuit diagram have been noted, impacting the discussion.
triplezero24
1. For http://www.pen.eiu.edu/~cuemc4/circuit.bmp picture.. Calculate the potential at point D.
2. I 15-V battery is connected to three capacitors in series. The capacitors have the following capacitances: 4.5microFarads, 12.0microFarads, and 32microFarads. Find the voltage across the 32microFarad capacitor.
I am so lost. :frown:
Please? I'm desperate!
I couldn't open your first picture... I get a "server not found" message.
For the second one... first find the equivalent total capacitance (combine 3 capacitors in series). The find the total charge on this equivalent capacitor.
You should then be able to get the charge on each capacitor (hint: this is really simple... if you are unsure read your textbook regarding combining series and parallel capacitors), and then get the voltage on each capacitor.
That might work. Mak sure you're soomed in all the way or it won't look right. Thanks for the help so far!
New link doesn't work either.
I'll attatch it.
Hmmm... absolute potential can't be calculated unless there's ground assigned somewhere. But I don't see one on the circuit. Are you sure the question asks for potential at D and not potential difference between 2 different points? Does the question mention about 0 volts being assigned somehwere?
Sorry. It says point A is grounded (V=0).
ok cool. So first find the current I in the circuit using KVL. So then you can get all the voltage drops across all the resistors (voltage drop across a resistor=current*resistance). Using that you should be able to find the potential at D. Be careful with signs!
Hope this helps!
  • · Replies 30 ·
