Decoding material specifications
  • Thread starter Thread starter ehilge
    Material
The discussion focuses on the specifications of materials, particularly pipes and fittings, with an emphasis on understanding the meanings and implications of various designations such as ASTM numbers, grades, and UNS numbers. Participants explore the relationships between these identifiers and their relevance to material properties and manufacturing processes.
  • One participant notes that the ASTM number specifies material composition and minimum mechanical properties, questioning whether the letters and number ranges have specific meanings.
  • Another participant explains that the UNS number serves as a unique alloy identifier that provides material composition but does not impose requirements for manufacturing or strength.
  • It is mentioned that ASTM A403 indicates wrought fittings, and the grade WP316 signifies standard stainless steel, as opposed to low carbon or high-temperature variants.
  • A participant inquires about the existence of standard rules for the numbering systems, particularly whether the range of the ASTM number conveys specific information about the material.
  • One participant asserts that the ASTM number corresponds to sections within the ASTM standard.
Participants express varying levels of understanding regarding the significance of the ASTM and UNS numbers, with some agreeing on their general roles while others seek clarification on specific aspects. The discussion remains unresolved on whether there are standard rules governing the numbering systems.
Participants acknowledge potential confusion regarding the implications of the ASTM and UNS designations, as well as the lack of clarity on whether the numbering systems follow specific rules or are arbitrary.
ehilge
Hello,
I've been trying to learn exactly how materials are specified, with particular reference to pipes and fittings, and I've come across some conflicting information and apparent confusion. The callouts I've been coming across have an ASTM #, grade #, amd sometimes a UNS#.
For example: ASTM A403 Grade WP316 (UNS S31600)
I'm fairly certain the ASTM number specifies the actual material composition and the minimum alowable mechanical properties, like tensile strength and yield strength. Does the ASTM number actually mean anything itself? i.e. does the 'A' or the fact its in the 400s indicate anything in particular about the material.
From what I can tell, the grade has more to do with the finish or how it is manufactured. I found that WP indicates wrought in this case. Again, does the number itself mean anything?
I have the most confusion with the UNS number. I can't tell if its just a different was to specify the same thing or if it adds more description to what has already been listed.
Any light you can shed on this subject would be most appreciated, thanks in advance for your help.
UNS number (Unified Numbering System) is a unique alloy identifier which provides the material composition. See here: http://en.wikipedia.org/wiki/Unified_numbering_system. This is just raw material data, it has no requirements for manufacturing, heat treats, post-work, strength, etc.
I don't have the spec in front of me, but it seems the ASTM specification deals with how to manufacture, test and rate stainless steel pipe fittings using stainless steels such as S31600 (stainless steel 316, which is a high-corrosion resistance steel).
Does that help?
The ASTM 403 indicates that this is for wrought fittings.
The Grade WP316 indicates that it is Standard [i.e. not LowCarbon (316-L) or High-Temp (316-H)]
Mech_Engineer told you what UNS was.
The UNS number is simply for reference if that is how a company references materials (say, in a different country). For example, you have your Standard 316 Stainless Steel, which is S31600, and you have Low Carbon 316 Stainless Steel, which is S31603. These can also be referenced as WP316 and WP316-L, respectively.
ASTM stands for the American Society for Testing and Materials.
See HERE
See HERE for the abstract of the ASTM A403 standard.
http://www.sunbeltsupply.com/docs/ASTM%20Materials%20Cross%20Reference%20Chart.pdf is a resource for ASTM material specifications data
Also, see page 68/77 of THIS for typical information that comes along with the spec you referenced.
Thanks for the information. Is there anything akin to standard rules for the numbering systems? Or are the numbers purely arbitrary? For example, if an ASTM number is in the 400 range, does that in itself give you any particular information on the item in questions?
It's the section in the ASTM standard.
  • · Replies 16 ·
  • · Replies 103 ·
22K
  • · Replies 27 ·
  • · Replies 17 ·
10K
