Why is the silver anode preferentially discharged in electroplating?
The discussion revolves around the electroplating of silver, specifically addressing why the silver anode is preferentially discharged over hydroxide ions in a silver nitrate solution. The scope includes theoretical aspects of electrochemistry and electrode potentials.
  • One participant expresses confusion regarding the preferential discharge of silver ions from the anode compared to hydroxide ions, referencing electrode potentials.
  • Another participant suggests that standard potentials should not be used for comparison and emphasizes the importance of considering formal potentials and the pH of the solution.
  • A participant questions whether the third equation related to oxygen should be used instead of the first for comparison.
  • One participant recommends calculating formal potentials for all reactions using the Nernst equation to clarify the situation.
Participants do not reach a consensus on the correct approach to understanding the preferential discharge in electroplating, with multiple competing views and suggestions remaining unresolved.
There are limitations regarding the assumptions about the pH of the solution and the potential involvement of various electrode reactions, which remain unresolved.
rogen
I am quite confusing about the concept of electroplating of silver.
As what I know, the silver anode gives out Ag+ while the Ag+ in the silver nitrate solution deposits on the cathode (e.g. a spoon).
However, why the Ag(s) on the silver anode is preferentially discharged instead of the OH- in silver nitrate solution?
Here are the electrode potentials:
O2(g) + 2 H2O + 4 e <--> 4 OH(aq) +0.4V
Ag+ +  e <--> Ag(s) +0.8V
O2(g) + 4 H+ + 4 e <--> 2 H2O +1.23V
As the process is carried out in alkaline condition, I suppose only the first two equations are involved. From the potential values, the OH- should be preferentially discharged rather than the Ag(s), but the actual situation is the opposite. I am not sure if I have misunderstood anything (e.g. the third equation is involved instead).
Chemistry news on Phys.org
You are comparing standard potentials, you should compare formal potentials, taking into account exact pH of the solution. Solution can't be alkaline - that would mean precipitation of AgOH, so it has to be neutral (if not slightly acidic). Add to that fact that most electrode reactions involving oxygen are sluggish and require substantial overpotentials to proceed quickly.
Thanks for your reply:smile:
So should I use the third equation instead of the first one for comparison?
You should start calculating formal potentials for all reactions (using Nernst equation). After that it can be already obvious what is going on. (Or not - I have not checked. But that's the most obvious line of attack).
Thankssssss Borek :cool:
I got the answer!
  • · Replies 26 ·
10K
