| New Reply |
Finding the voltage in a non- series/parallel circuit |
Share Thread | Thread Tools |
| Jul14-12, 08:53 AM | #1 |
| Jul14-12, 09:17 AM | #2 |
Why are you shorting out A and B? In the circuit you have shown, R4 is just dangling out there, not dissipating any power.
| Jul14-12, 09:19 AM | #3 |
I haven't checked your attempt but did you notice that when calculating Vab you can:
1) ignore R1 (eg remove it because it's parallel with V1). 2) You can also short R4 because the current in R4 = 0 Redraw the circuit and you end up with a v. simple two resistor circuit with just R2 and R3 as a potential divider.. Vab = V1 * R3/(R2+R3) = 50 * 220/(150+220) = 29.73 V |
| Jul14-12, 09:24 AM | #4 |
To calculate the power apply KCL to the battery positive node.
Hint: Calculate the current flowing in R3 from Vab/R3. |
| Jul14-12, 09:52 AM | #5 |
No current flows through R4 so Vab is the same as the V across R3.
R2 and R3 form a potential divider |
| Jul14-12, 12:16 PM | #6 |
| Jul14-12, 01:32 PM | #7 |
I would do it this way..
Apply KCL at the battery positive node.. Ibat + IR1+IR2 = 0 or - Ibat = IR1+IR2 Note that with R4 open circuit then.. IR2=IR3=VR3/R3=29.73/220= 135mA As R1 is in parallel with the 50V supply then.. IR1 = 50/47= 1.064A Substitute these two values into the above -Ibat = 1.064 + 0.135 = 1.199A call it -1.2A Power = V * I = 50 * -1.2 = -60W |
| New Reply |
| Tags |
| circuit, pi-t conversion, power, voltage |
| Thread Tools | |
Similar Threads for: Finding the voltage in a non- series/parallel circuit
| Finding the frequency of a series parallel circuit using complex notation | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Finding Which Resistance and Which Circuit is Series and Which is Parallel | Introductory Physics Homework | 4 | ||
| finding ZL for a series-parallel RL circuit | Engineering, Comp Sci, & Technology Homework | 6 | ||
| Finding resistance using a series and parallel circuit? | Introductory Physics Homework | 8 | ||
| finding voltage drop in parallel and series circuits | Introductory Physics Homework | 4 | ||
