Calculating the frequency of the fundamental vibrational mode
The discussion centers on calculating the frequency of the fundamental vibrational mode of carbon monoxide (CO) based on its absorption of electromagnetic (EM) radiation. The stretching frequency of CO is approximately 2100 cm-1, which corresponds to an energy of about 0.3 eV. The energy levels for vibrational modes are described by the equation En = hf(n + 1/2), leading to the conclusion that the energy of the n=0 mode is 0.15 eV. This establishes a clear relationship between vibrational frequency and energy absorption in molecular bonds.
  • Understanding of vibrational spectroscopy
  • Familiarity with the concepts of energy quantization in quantum mechanics
  • Knowledge of the relationship between frequency and energy (E = hf)
  • Basic principles of molecular bonding and stretching frequencies
  • Research the application of vibrational spectroscopy in identifying molecular structures
  • Study the quantum mechanical model of molecular vibrations
  • Explore the implications of vibrational frequencies in chemical reactions
  • Learn about the use of Fourier Transform Infrared (FTIR) spectroscopy for analyzing molecular vibrations
Chemists, physicists, and students studying molecular spectroscopy, particularly those interested in the vibrational characteristics of diatomic molecules like carbon monoxide.
mycotheology
Can you calculate the frequency at which a bond vibrates when you know what frequencies of EM radiation it absorbs? Using carbon monoxide as an example. It has a stretching frequency at around 2100 cm-1. In electron volts, that would be around 0.3 eV. If I'm not mistaken, this is the energy it absorbs to jump from n=0 to n=1 (or is it n=1 to n=2?). Anyhow, if its the former then ΔE = [itex]\frac{3}{2} - \frac{1}{2}hf[/itex] = hf.
I know that the equation to calculate the energy of vibrational normal modes is [itex]E_n=hf(n + \frac{1}{2})[/itex] so wouldn't that mean that the energy of the n=0 mode is equal to [itex]\frac{0.3 eV}{2}[/itex]?
That's certainly what it means.
The classical picture is that this is the frequency of the fundamental at which the two atoms vibrate towards each other.
  • · Replies 16 ·
