Which have unusually large dipole moments?
  • Thread starter Thread starter cjc0117
    Dipole Moments
The discussion revolves around the dipole moments of three compounds: fulvene, calicene, and a third unnamed compound that resembles calicene but lacks a double bond in its three-membered ring. Participants explore the reasons behind the dipole moments of these compounds, particularly focusing on the differences in resonance structures and aromaticity.
  • Some participants assert that calicene has a very large dipole moment due to its resonance structures achieving aromaticity.
  • There is uncertainty regarding the dipole moment of the third compound, with one participant suggesting it might have a dipole moment similar to or greater than fulvene.
  • One participant notes that the third compound was incorrectly drawn on a test, which led to ambiguity regarding its dipole moment.
  • Another participant argues that the stabilization from generating two aromatic structures in calicene may lead to a larger dipole moment compared to the third compound's resonance structure.
  • There is a discussion about the relative stability of primary versus tertiary carbocations in the context of dipole moments, with some participants questioning whether the cyclopropyl cation's instability outweighs the benefits of a tertiary carbocation.
Participants express differing views on the dipole moments of fulvene and the third compound, with no consensus reached on the latter's dipole moment. The discussion remains unresolved regarding the exact relationships between the compounds' structures and their dipole moments.
There are limitations due to the incorrect drawing of the third compound, which affects the clarity of its dipole moment assessment. Additionally, the discussion involves assumptions about the stability of carbocations and the impact of aromaticity on dipole moments.
cjc0117
There are three compounds:
1.) fulvene
2.) calicene
3.) I don't know the name of the third compound. It looks like calicene except that there is not a double bond inside of the three-membered ring.
Anyways, it turns out that fulvene and calicene have unusually large dipole moments, but not the third compound.
One answer choice was only calicene, another was both calicene and fulvene. There was no answer choice for all three.
I knew that calicene definitely has a very large dipole moment, because the resonance structure formed when the pi electrons joining the two rings moves to the carbon of the pentadiene acheives two aromatic compounds. As for fulvene and the third compound, only one ring acheives aromaticity. The resonance structure for fulvene has a primary carbocation substituent, and the one for the third compound has a tertiary carbocation substituent, and angle strain. I thought that if fulvene had an unusually large dipole moment, so must the third compound. The resonance structure for compound 3 has angle strain, but I thought the overall stability would be similar to the stability of a primary carbocation.
I could not choose all three, and I believed the third compound would have an equal or greater dipole moment than fulvene, so I went with just calicene. But I'm wrong. Could someone help me understand why fulvene would have a larger dipole moment than the third compound?
And you say this third compound doesn't have the double bond in the three-member ring that calicene has?
Hmmmm.
...the pi electrons joining the two rings moves to the carbon of the pentadiene acheives two aromatic compounds.
Thanks for the response.
As I said, the original answer was both fulvene and calicene. The resonance structure for fulvene only has one aromatic ring yet still apparently has a large dipole moment, so we can't dismiss the third compound on the basis that its resonance structure only has one aromatic ring instead of two.
Anyways, as it turns out, the third compound was drawn incorrectly on the test (there should not have been a double bond between the 5-membered ring and 3-membered ring). If it has been drawn correctly, there would be no ambiguity and the answer would be just calicene and fulvene. As it was drawn on the test, the third compound did have a large dipole moment. It was just an error. I wanted to edit my post to say this but I couldn't find the edit option.
No, but if the generation of two aromatic structures stabilizes the charge separation in the zwitterion it should have a larger dipole moment than if it resonated between a structure containing a relatively unstabilized cyclopropyl cation and the neutral structure, the equilibrium favoring the neutral structure rather than the zwitterion.
So you're saying that despite the fact that the resonance structure for fulvene has a primary carbocation as opposed to the resonance structure for the third compound (really wish I knew the name) which has a tertiary carbocation, the fact that it is also a cyclopropyl cation far outweighs the relative stability gained by having a tertiary carbocation as opposed to a primary carbocation? So much so that it does not have a large dipole moment, whereas fulvene does?
Sorry, I got a little fixated on calicene/'not-calicene' comparison and forgot you actually asked about fulvene. You're right of course, if fulvene has an unusually high dipole moment then 'not-calicene' should as well.
BTW, I would call 'not-calicene' 1-(cycloprop-1-ylidene)-2,4-dicyclopentadiene.
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 264 ·
33K
