Is there such a thing as true darkness?
  • Context: Graduate
  • Thread starter Thread starter phaeton
The discussion revolves around the concept of "true darkness" and whether it exists in the context of electromagnetic radiation. Participants explore the definitions of light, the implications of thermal radiation, and the subjective versus objective interpretations of darkness. The conversation spans theoretical considerations, biological perceptions, and the nature of electromagnetic waves.
  • Some participants propose that true darkness may not exist due to the omnipresence of electromagnetic fluctuations, even in seemingly dark environments.
  • Others argue that darkness can be defined as the absence of photons in the visible spectrum that can be detected by human eyes.
  • A participant suggests that subjective experiences of darkness may vary, particularly for individuals with different visual capabilities.
  • There is a discussion about whether phenomena like phosphenes can be classified as vision or merely imagination.
  • Some participants assert that all electromagnetic radiation, including those outside the visible spectrum, can be considered light, while others emphasize the human-centric nature of the term "light."
  • Several contributions highlight that even in deep space or a perfectly opaque box, thermal radiation would still emit photons, suggesting that true darkness is unlikely.
  • One participant questions the definition of photons and whether those outside the visible spectrum can still be classified as such.
  • There are corrections and refinements regarding the terminology used to describe black bodies and their radiation properties.
Participants express multiple competing views on the existence of true darkness and the definitions of light and vision. The discussion remains unresolved, with no consensus reached on these complex topics.
Limitations in the discussion include varying definitions of darkness and light, the subjective nature of human perception, and the complexities of electromagnetic radiation that are not fully addressed.
phaeton
Considering that what most people think of as light is just the visible spectrum of electromagnetism, while much more exists on either end, are the frequencies beyond either end of the visible spectrum still light? If so, since electromagnetic fluctuations permeate the known universe, is there any such thing as true darkness?
If you consider the radiated thermal spectrum of an object at finite temperature the you could expect the occasional photon of visible em radiation even inside a coal mine with the lights all turned off. But, to an Engineer this is near enough darkness for Jazz!
Yes, if humans define darkness as the absence of photons in the visible spectrum that can be received by retinal cells.
Of course if you lock yourself in a room shut off from enough receivable energy in the visible spectrum your brain will eventually start making things up for you.
This is a very complex question to my thinking.
Do you mean subjective or objective darkness? If the former, I submit that a totally blind person might be considered to be in true darkness regardless of environment. Even that might depend upon the pathology. If a sighted person is in an enclosed room or simply sticks his head into a box, he'll "see" spark-like dots due to random interactions of cosmic rays or other irritating things with the photoreceptive cells in his eyes. They're called "phosphenes". That, to me, counts as vision, but can it be considered "darkness" simply because no photons are involved?
I wouldn't class 'seeing things' that aren't there as vision. It's more like 'imagination'.
The whole point is that they are there. They're subatomic particles. Would you consider a track in a cloud chamber to be imaginary just because you can't see the particle that created it?
The whole EM spectrum is light, and the light that we see is visible light. There is such a concept as true darkness, but based on what we observe it's very likely that this true darkness doesn't exist anywhere in the known universe. Even if you put someone in deep space, inside a black box, the box material would still emit thermal radiation inward because its temperature is above zero.
This is more to the point which i was after. The others were digressing into human biological interpretation of the visible spectrum as opposed to the full natural spectrum. This seems a relatively definitive argument in my favor.
With that being said, I'll pose a new question:
If there is no true darkness in the known universe due to electromagnetic fluctuations, are the resultant radiations from said fluctuations which fall outside either end of the visible spectrum still photons? or is the visible spectrum alone defined by the manifestation of photons?
I am just now getting into physics with more depth than before so I may be posing an ignorant question here, but it will help me know whether or not to ask the next question which I have in mind.
The photons can be in the visible range or outside of it. I would hazard a guess that most are in the microwave region (the cosmological background radiation), but there are still some in the visible region from non-blackbody sources, eg. starlight. I'm not sure whether a human eye could detect it in the darkest regions, but it's still there.
MikeyW said:
The photons can be in the visible range or outside of it. but there are still some in the visible region from non-blackbody sources, eg. starlight.
Stars are black bodies. And everything is actually a black body. The name is misleading. As everything emits radiation. Cooler objects you can't see it, because the intensity of the light is very weak in the visible spectrum. But as they get hotter, the intensity of the light increases in the visible spectrum and you can see the light. First they glow red and then white hot (white hot as it's called - and if it is glowing white then it is hot).
There is always visible light everywhere - there's just not always enough to see it. Even deep space is full of starlight.
Here's a graph of black body radiation, and the visible spectrum. You see you need quite a bit of heat to see the heat.
http://www.egglescliffe.org.uk/physics/astronomy/blackbody/Image21b.gif
Even if you shut yourself in a perfectly opaque box in deep space, the box will come in thermal equilibrium with the cosmic microwave background, rise to 3 kelvin, and reradiate that heat continously according to a (mostly) blackbody curve. Even at just 3K, there is some amount of radiant intensity at visible wavelengths.
If you don't digress into how humans perceive the world about them through EM waves, chemical means, or pressure receptors with the question that was posed in this case, one can go way off into fantasy land. In fact at the base of any scientific activity one must always be cognisant of the limitations of human perception. People completely forget so many filtering mechanisms, etc... that the brain has given us through natural selection that don't have a darn thing to do with finding photons.
We merely got rid of that rubbish for you to get to the serious stuff :)
Thank god I can't always feel my clothes touching all parts of my body... it would be damn difficult for me to type in this particular discussion.
All electromagnetic radiation propagates by way of photons.
'Light' is a tricky term; it tends to be human-centric. Bees and birds and many other animals can see well into the IR and UV range, using optical sensors, so that is one way of defining light that is not human-centric.
If you go much farther outside the visible spectrum, you can no longer use optical sensors. You get into microwaves on one end and X-rays on the other.
Thanks a lot, you saboteur! Now I'm starting to itch.
So now you can think about your breathing ;)
:smile:
(I don't know whether or not you actually realize how funny that is, given my circumstance.) :biggrin:
You got me on this one. "non-blackbody" was an awful word for me to use.
This is great. I had suspected this would be the case. Thank you all for helping me work through this. Now I must pose yet another question which will take me closer to my end goal:
Since, in a matter of speaking, there is "no true darkness," because there are photons being propagated within every vestige of the known universe, would that imply that the universe as a whole is made entirely from and full of substance?
To qualify, this touches on a still raging debate on whether photons actually have mass or not, or whether photons have both mass and no mass at the same time(in a similar way that photons act as both wave and particle). From the standpoint that photons do indeed have mass, and from the technical definition of substance as the mass or tangibility of a thing, then it would follow that the answer to my above question would be yes. But it could also be argued that as photons have no mass, and hence, no literal substance, and that literal substance is scarce in the universe. This would leave us with a no to my above question.
Now, touching on the metaphysical side, and re-qualifying what substance is outside of it's literal and physical definition, even if photons have no mass, could it be argued that they still have substance? Which would allow for a yes to my [first] above question in either case.
Now to pose my suggested re-qualifying of what substance is: can something which has function, lack substance? For photons, whether mass-less or not, have function. If something has function, would that not imply, philosophically, that it must have substance?
I fear though that I may be posing a question which cannot be properly answered in a general physics forum, so pardon my digression, against my own previous resistance, into human perceptions.
No, it would not.
jbriggs444 said:
No, it would not.
And your reasoning is...?
With any discussion as difficult as this one can always digress into human perceptions. Definitions become extremely important. Many times you will discover that people do not even have the same definition of some noun (and the don't realize it) and this leads to disagreement. Their models, since this is all modeling, don't fit with each other because they do not even agree on the same basic definitions. They may even have the same mathematical definition but then the metaphorical model in their heads actually differ.
It usually happens because most of us are humans and realize limitations in symbolic language and reasoning.
There are groups of physicists and philosophers that are trained in both that look for flaws in some very important topics in physics. And there are many papers and groups that do exactly what you are attempting here.
Is there a "raging debate"? Experiments to find the rest mass of a photon have all come up with steadily decreasing values for the maximum possible mass but, of course, will never yield a value of Zero because that's how measurement works; you cannot measure Zero.
It certainly does become more tricky when trying to reconcile two seemingly divergent schools of thought. Though, it is lately becoming more accepted that interdisciplinary approaches are far more beneficial. Do you by chance have an opinion on this particular matter?
I was merely referencing my introduction to this forum. I was looking for some answers to said debate when I was lead to a thread on this forum which is in it's sixth year on continually renewed interest and debate. I may have chosen poorly when using the word "raging" but it seemed to me that there are still are large number of people on both sides of this issue. It may also be my own ignorance which I can blame, but it seemed to me that the arguments were nearly in favor of photons having mass/substance in some way or another.
My mind is a blank tablet, I'm here to learn.
Photons have energy, which contributes to gravitation. They can impart momentum to objects and once absorbed the energy adds to the mass of a system. In fact, any system with light in it is more massive than a near-identical system that has no light. So we say light has no REST MASS, but it does indeed have energy and thus can add mass to a system, though it has no mass itself.
Excellent, that seems relatively straight forward... But seeing as how photons are capable of such things, capable of anything at all, would that not lend credence to thought of photons possessing substance, whether that be mass or energy? Maybe a better question is whether or not substance should be re-defined as encompassing more than mass, but energy as well...
An even better question: is there a scientifically rigorous definition of the word 'substance' in the first place?
To say that the universe has electromagnetic radiation throughout and conclude that it is both full of and made from some unspecified substance... That is not a coherent argument. And the conclusion is not testable.
Oh Dave!
You know ---- stuff, gubbins, guff or something.
:devil:
substance [ˈsʌbstəns]
n
1. the tangible matter of which a thing consists
2. a specific type of matter, esp a homogeneous material with a definite composition
3. the essence, meaning, etc., of a written or spoken thought
4. solid or meaningful quality
5. (Physics / General Physics) material density a vacuum has no substance
6. material possessions or wealth a man of substance
7. (Philosophy) Philosophy
a. the supposed immaterial substratum that can receive modifications and in which attributes and accidents inhere
b. a thing considered as a continuing whole that survives the changeability of its properties
8. (Christian Churches, other) Christian Science that which is eternal
9. a euphemistic term for any illegal drug
in substance with regard to the salient points
Here is what i found to be a collection of modern definitions of the word substance, I made bold the definitions which i thought to be pertinent. The first and fifth the the ones which i seem to be having trouble with. It is this definition which I seem to want to change in a way which includes energy as well. If this were the case then the fifth definition would be nullified. I believe this is a proposition worth looking into and capable of supporting. The forth definition suggests that things with meaningful qualities posses substance, and I believe photons to fall within this category.
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 40 ·
