Unanswered Query: Is E(r) Undefined at r=R?
  • Context: Graduate
  • Thread starter Thread starter quasar987
The discussion centers around the behavior of the electric field E(r) at the radius r = R of a uniformly charged spherical shell with areal density σ. Participants explore the implications of using Coulomb's law versus Gauss' Law to determine the field at this boundary, questioning whether the field is undefined at r = R.
  • One participant notes that using Coulomb's law directly leads to an undefined field at r = R due to a division by zero in the integral.
  • Another participant argues that the field is defined and has a finite value, suggesting that one should compute the field inside and outside the sphere and analyze the graph for insights.
  • Some participants express skepticism about the assistant teachers' claims that the field is undefined, indicating a lack of trust in their explanations.
  • There is a discussion about the appropriate formulas to use for calculating the electric field from a surface charge density, with references to Griffiths' equations.
  • A later reply mentions that while the field may be undefined at the boundary of a charged surface, it is important to consider that real physical systems have thickness, leading to a smooth transition of the field values.
  • Another participant points out that there is always a discontinuity in the electric field at the boundary of a charged surface, specifically in the normal component, while the parallel component remains continuous.
Participants express differing views on whether the electric field E(r) is undefined at r = R. Some argue it is undefined based on Coulomb's law, while others assert it is defined and finite, particularly when applying Gauss' Law. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the limitations of using an infinitely thin shell in theoretical calculations, noting that in practical scenarios, the shell would have thickness, affecting the behavior of the electric field.
quasar987
I asked the following question to my teacher through email a week ago, and he hasn't replied.
Consider a uniformly charged spherical shell of radius R and areal density [itex]\sigma[/itex] and consider also a cartesian system whose origin coincide with the center of the shell.
Clearly if we attempt to calculate the field at r = R directly through Coulomb's law, we obtain that the field is undefined, because we'd have a (r' - r') at the denominator (equ. 2.7 in Griffiths)
But, as Griffiths remarks (pp.88), if we apply Gauss' Law, we obtain that the field at r = R is of magnitude [itex]\sigma \epsilon_0[/itex]. So what should we think? Is the sclalar function E(r) undefined at r = R or not ?!
It is defined...Naturally,since it has a finite value...Compute the field inside the sphere and outside and then plot the graph...Do you see anything interesting??
Daniel.
P.S.How do you compute the field using Coulomb's law?
Well it's not so simple I think, since, like I said, using coulomb's law, it DO comes out undefined. Both assistant teachers said it was undefined, but I don't trust them.
Griffith's equ. 2.7 I have written in post #13 of the infamous Gauss' Law proof thread. I would copy it but for some reason, clicking the formula does nothing so I can't retrieve the code.
You can see, in the integral, if [itex]\vec{r} = \vec{r'}[/itex], it is undefined.
Are u referring to poste #6 and its first formula?
If so,then I have 2 objections...
a)That is not Coulomb's law...
b)You cannot use that formula...
Which formula need you use?
Daniel.
Yes, I'm referring to the scalar equation of the field from post #6. That is the expression Griffiths gives for the field produced by a continuous distribution of charge.
Yes,that's true.But that one is valid for [itex]\rho (\vec{r'})[/itex] which is A VOLUME DENSITY OF CHARGE.You need another formula for a SURFACE DENSITY OF CHARGE...
Daniel.
Oh. Right. Well. This one is given right before. It has exactly the same form, except
1) The integral is over a surface.
2) [itex]\rho(\vec{r'})[/itex] is replaced by [itex]\sigma(\vec{r'})[/itex]
3) dV is replaced by dA
It is undefined. It is related to the fact that an infinitely thin shell is unphysical. In the limit, the field has a discontinuity at r=R, but in real life, the shell does have a thickness and the field varies smoothly from zero inside the shell to its max value just outside.
Mmh, but how should one interpret the result provided by Gauss' Law:
At theboundary of a charged surface there's always a discontinuity in the electric field. Specifically in the normal component of the electric field (normal to the surface). The parallel component is continuous.
I think the relation was:
[tex](\vec E_1 - \vec E_2)\cdot \vec n = 4\pi \sigma[/tex]
or
[tex](\vec E_1 - \vec E_2)\cdot \vec n = \sigma/\epsilon_0[/tex]
depending on your choice of units.
The n is the unit normal to the surface.
Therefore strictly the field is not defined. You always have a singularity in E precisely at the point where charge is.
Since this is an approximation, as krab pointed out, in reality E is always smooth.
  • · Replies 29 ·
