M's Electric Field Calculation for a Uniformly Charged Wire
  • Thread starter Thread starter hmmm
    Charged Wire
The problem involves calculating the y-component of the electric field generated by a uniformly charged wire with a specified charge density, located along the x-axis. The electric field is to be evaluated at a point on the y-axis, specifically at y=3m.
  • The original poster attempts to conceptualize the wire as an infinite number of point charges but expresses uncertainty about calculating the electric field components. Some participants suggest breaking down the electric field into components and integrating over the length of the wire, while others note the cancellation of horizontal components and the addition of vertical components.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the integration process and the need to consider the geometry of the situation, but no consensus has been reached on a specific method.
Participants are discussing the implications of symmetry in the problem and the necessity of integrating over the wire's length to find the electric field components. There is an emphasis on the relationship between the charge density and the elemental lengths used in the calculations.
hmmm
A uniformly charged wire with a charge density of 4 microCoulombs/meter lies on the x-axis between x=1m and x=3m. What is the y-component of the corresponding electric field at y=3m on the y-axis?
I'm not really sure where to go with this. I want to treat the rod as an infinite number of point charges but I'm not sure how to calculate (y-component of) the electric field caused by each of these points.
suppose there is a point charge on the point y=3 , find the electric fireld there, actually the electric field there for suppose due to the charge on the X=1 m can be broken up into two components one along -x and another along +y axis..they can be computed separately by integrating ..in this case i think you only need to compute for the y aixs one...for the integration take elemental lengths dx for the wire...
glad to be of help,
Arpan Roy
royarpan@hotmail.com
Note that, for each "dx" on one side of the point, there is a corresponding "dx" the same distance on the other side. The horizontal components of force of those will cancel but the vertical components will add.
Since this problem is not symmetrical, the horizontal components of the [itex]\vec{E}[/itex] do not cancel. The easiest approach is probably to calculate the vertical ( [itex]\vec{E_y}[/itex] ) component separately.
Draw a diagram of the situation with the given axis, and choose an arbitrary piece of charge [itex]dq[/itex] of the wire.
Come up with an equation for the corresponding electric field [itex]\vec{dE}[/itex] due to [itex]dq[/itex] at the point (0,3).
Figure a way to represent [itex]dq[/itex] in terms of [itex]dx[/itex] so you can integrate with respect to x.
(hint: it involves the linear charge density )
Break the equation into the vertical component of [itex]\vec{E}[/itex] and integrate with respect to x
(hint: [itex]\vec{dE_y} = \vec{dE} sin \theta[/itex] where theta is the angle between a line parallel to the x-axis and [itex]\vec{E}[/itex] )
(another hint: you will have to come up with an equation for [itex]sin \theta[/itex] in terms of x so you can integrate )
good luck :smile:
-MS
