New Reply
Langevin DE
Share Thread Thread Tools
Jul21-12, 02:59 PM   #1
Langevin DE
Hi
I am reading about the Langevin stochastic differential equation
[tex]
\frac{d}{dt}p = -\alpha p + f(t)
[/tex]
where p is the momentum and f(t) the Langevin force. By definition <F(t)>=0 and <f(t)f(t')> = 2Dg(t-t'), where g is the second order correlation function.
My question is, why is there a factor 2 in the expression for <f(t)f(t')>? I can't seem to find an answer in any book, but they all write the factor.
I would be glad to recieve some feedback.
Best,
Niles.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul21-12, 04:51 PM   #2
Recognitions:
There are two phenomenological ways of describing simple Brownian motion.
One is with something called a Fokker-Planck equation http://www.pma.caltech.edu/~mcc/Ph127/b/Lecture17.pdf . In the definition of the Fokker-Planck equation there is a quantity called the diffusion constant D.
The other is with the Langevin equation. You are right that there is no need to start off with the "2" in the definition of the Langevin equation. Let's say you start off "g" instead. You will find that you can derive a Fokker-Planck equation from the Langevin equation where g=2D, with the g coming from the Langevin, and the D from the Fokker-Planck. Since they knew that, they just used 2D in the initial definition. See http://web.phys.ntnu.no/~ingves/Teac...loads/kap6.pdf Eq 6.3, 6.8, 6.27 and 6.35.
Jul21-12, 04:57 PM   #3
Thanks, that is very kind of you. These things are really interesting. I need to find a good book on this topic, uptil now I have just been using the web.
Best.
Niles.
Jul21-12, 04:59 PM   #4
Recognitions:
Langevin DE
I've been learning stuff from Kurt Jacob's book http://books.google.com/books?id=bx8...gbs_navlinks_s . It's was quite accessible for me (I'm a biologist).
Jul21-12, 05:03 PM   #5
Thanks, I just checked my library, and they have it. I'll pick it up Monday.
New Reply
Thread Tools
Similar Threads for: Langevin DE
Thread Forum Replies
How to pronounce Langevin in English? General Physics 4
Langevin curve fitting Atomic, Solid State, Comp. Physics 3
Langevin curve fitting Programming & Comp Sci 0
[SOLVED] langevin equation Advanced Physics Homework 2
From Langevin to Fokker-Planck Calculus & Beyond Homework 2
