How Do Electrons in Water Clusters Influence Their Electronic Spectra?
  • Thread starter Thread starter physicsss
    Chemistry
Daniel Neumark's study on negatively-charged water clusters reveals that for clusters containing 50 water molecules, the extra electron is predominantly located in a central void, while in clusters with fewer than 20 molecules, it resides on the surface. This finding resolves a long-standing debate regarding the electron's positioning in relation to cluster size. The study provides insights into how electronic spectra can differentiate between these configurations based on energy requirements for excitation, influenced by the electron's location.
  • Understanding of negatively-charged water clusters
  • Knowledge of electronic spectra and excitation energy
  • Familiarity with molecular geometry and electronic repulsion
  • Basic principles of quantum mechanics related to electron behavior
  • Research the principles of electronic spectra in molecular clusters
  • Explore the effects of molecular size on electron localization
  • Study the role of electronic repulsions in molecular interactions
  • Investigate methods for calculating excitation energy in molecular systems
Researchers in physical chemistry, theoretical chemists, and anyone studying molecular interactions and electronic properties of water clusters.
physicsss
Daniel Neumark recently attracted attention for his study of negatively-charged water clusters. The clusters are "globs" of water molecules with one extra electron. He found that, for clusters with 50 water molecules, the extra electron was almost always confined to a void in the center of the cluster. For clusters with less than 20 water molecules, the electron was almost always on the surface of the cluster. Over the last 20 years, theorists have speculated as to whether the electron would be inside or outside the cluster, and if both, which case would be favored for small clusters and which would be favored for large clusters. Now the answer is known.
Using what you now know about the behavior of electrons and wavelengths of radiation, and the space-filling size of water molecules, how might the electronic spectra measured by Prof. Neumark have distinguished the two types of clusters? Justify your answer with calculations, and explain any assumptions.
Hints and one more question: The spacing between nearest oxygen atoms in ice is about 0.28 nm. Further, the extra electron does not significantly penetrate the space occupied by a water molecule. Suggest the physical reason for why the electron does not penetrate that space.
Can someone help me with is? I have no clue...
Chemistry news on Phys.org
You have to make some attempt. Did you try Googling ?
If the electron was on the surface, relatively little energy must be given to excite it, however, if it was in the center, the energy must be higher. The energy can be calculated on the position of the excitation peak.
The reason why the extra electron cannot penetrate the small space between two oxygen atoms may be due to electronic repulsions, since oxygen has two non-bonding electron pairs, there is a considerable repulsion. A fifth one cannot easily approach to them, I think.
9K
