Questions about EMP Effects in Spacecraft
  • Context: Graduate
  • Thread starter Thread starter Phil_B
The discussion centers on the effects of electromagnetic pulses (EMPs) generated by nuclear explosions in space, specifically within spacecraft. Key points include that the Compton Effect requires a gradient in Compton electrons to produce a significant EMP, which is unlikely in the limited atmosphere of a spacecraft. Additionally, while electrical equipment may be destroyed, the risk of electrocution for individuals inside the spacecraft is minimal due to rapid charge equilibrium. Protection strategies such as using a Faraday cage for sensitive equipment are recommended, but grounding is not necessary for effectiveness.
  • Understanding of the Compton Effect and its role in EMP generation
  • Knowledge of electromagnetic pulse (EMP) effects on electronic systems
  • Familiarity with Faraday cages and their applications in protecting electronic devices
  • Basic principles of charge distribution and equilibrium in electrical systems
  • Research the Compton Effect and its implications in nuclear physics
  • Learn about EMP protection strategies for spacecraft and sensitive electronics
  • Explore the design and effectiveness of Faraday cages in various environments
  • Investigate the effects of EMPs on human safety and electrical systems in confined spaces
Science fiction writers, aerospace engineers, and electrical engineers interested in the implications of EMPs in spacecraft and the protective measures for electronic systems in extreme environments.
Phil_B
Hi everyone,
I’m a wannabe scribbler of Science Fiction trying to get things right in a story I’m working on...so I thought the best idea was to come and ask the experts and those who know far more than I ever will in a place such as here.
Ok I’m now done with the flattery, but it will hopefully get me somewhere ;-)
Basically I’m working with a limited nuclear exchange in space. Is there likely to be enough air in a spacecraft for enough of a Compton Effect to produce a significant EMP or am I looking at needing a planetary volumes of atmosphere to produce anything approaching destructive levels.
Secondly, with a nuclear produced EMP am I looking at any noticeable effects for those living within such a tin can, other than the destruction of electrical equipment? Are there going to be people electrocuted, because they were in contact with metal surfaces when the blast occurred, would someone who was not touching any surfaces be carrying a charge after the blast or would the limited volumes of atmosphere mean a rapid return to equilibrium?
Last one... other than the pulse directly fed into a system via antenna and communication dishes, I know that if there is an EMP I’m looking at problems caused by induced currents in long wires due to the low frequencies, gaps in electronic casings acting as wave guides for the higher frequencies. Is protection as simple as disconnecting long wires and having more sensitive electrical equipment in a sealed tin box (though insulated from the box itself)? Would this 'Faraday box(?)' have to be earthed?
Thanks very much,
Phil
It's not the air, per se, that causes EMP. There are two requirements for EMP: (1) the existence Compton electrons and (2) a gradient in Compton electrons on the scale of the range of the the photons. E.g. you would have no EMP in a perfectly uniform atmosphere (given a symmetric explosion) because there would be no dipole moment to the charge distribution.
  • · Replies 21 ·
  • · Replies 16 ·
