Thread Closed
inside a container with non-pure helium
Share Thread Thread Tools
Jul30-12, 09:44 PM   #1
Is helium miscible with O2, N2 or any of the other gases in air?
If a container were filled with 95% helium and 5% O2, would the O2 gas settle to the very bottom of the container, leaving very pure helium gas at the top?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jul31-12, 12:58 AM   #2
The helium won't react with the O2 or N2. The helium would mostly settle to the top of the container, but I'm not sure about the purity. You'd probably get a small amount of O2 and N2 along with any sample you pulled out.
Jul31-12, 05:22 AM   #3
krd
Quote by papernuke View Post
No, they would mix. Think of it this way, the earth's atmospheric gases do not separate into layers according to relative weights of each gas.
You can remove the oxygen and nitrogen by reducing the temperature and liquefying them. It's a form of distillation.
Jul31-12, 08:21 AM   #4
mfb
Mentor
If you fill your room carefully, you can get unmixed gases for a while. But if you wait long enough (or have enough sources of turbulence), you will get a mixture of those gases, with slightly more helium at the top.
Jul31-12, 09:51 AM   #5
Quote by krd View Post
Actually, the atmosphere is separated into layers according to the relative weights of gasses to some degree. Each layer of the atmosphere (mesosphere, stratosphere etc) has a different composition of gasses. One reason that there's a lot of gas that doesn't take its expected position in the atmosphere is because there are heavier molecules that the gas molecules can react with and attach themselves to. In the case of a container with only helium, nitrogen and oxygen, there are no reactions happening to form heavier molecules, so they should separate into layers. You can demonstrate the ability of fluids to separate into layers with some vegetable oil and water. Put them in a container and mix them together, and they'll separate again into layers, because the oil and water don't react well and they have different densities.
Jul31-12, 10:32 AM   #6
I'm not sure that is true? Ethanol and water have very different densities but they mix completely. Liquid mixing is totally different to gaseous mixing because of the intermolecular bonding in liquids.
I think the gases will partially stratify, but they will certainly not be ordered into perfect layers.
Jul31-12, 11:22 AM   #7
Quote by MikeyW View Post
Vegetable oil isn't ethanol, that's alcohol. I agree that the gases won't make perfect layers like the liquids do because they lack the intermolecular forces, but I can show you a demonstration that allows you to visualize a similar layered separation of gases.
http://youtu.be/ckaJs_u2U_A
This is quite a heavy gas, but the ratio of weight between the SF6 in that video, and air molecules is smaller than that between He, and O2, or He and N2. This suggests that the He would separate from the other gases in the container even better than the SF6 in this video separates from the air.
As for the O2 and N2 mixing or separating, they might be close enough in molecular weight that they don't separate well.
Jul31-12, 01:00 PM   #8
mfb
Mentor
The SF6 does not separate there, it gets injected at the bottom of the container as carefully as possible. If you watch the "sinking" around 3:50 carefully, you can see a boundary layer, where the SF6 concentration gradually increases towards the bottom. Filling more SF6 causes the boat to go down significantly, but only at 3:58 it is fully within the SF6 and sinks quickly.
The atmosphere has a height of >10km, do not expect the same layers in a small room.
Jul31-12, 03:09 PM   #9
krd
Quote by Nessdude14 View Post
But gases don't behave as fluids. And you will find heavier molecules in the upper atmosphere.
Gases are more free to move around so they will mix. And there isn't much of anything in the upper atmosphere, all gases are densest near the ground.
I'm pretty sure thermal equilibrium would also cause the gases to mix.
Jul31-12, 04:11 PM   #10
But when a volume of helium is released into the open, all of it is pushed up by the buoyancy of the surrounding air. And in that case, only helium rises, no oxygen or nitrogen mixes with the helium and rises with it.
Wouldn't the same happen in the smaller container? The 95% helium would be displaced upwards by the buoyant force by the 5% of oxygen in the tank.
And also, since helium rises only up to the point where it is no longer affected by the buoyant forces, does that mean that there is a slight layer of helium in the upper upper atmosphere? I don't think a helium atom would have acquired enough kinetic energy by then just from buoyant forces to have an escape kinetic energy.
Jul31-12, 05:45 PM   #11
mfb
Mentor
If you release it carefully, yes. If not, it mixes.
Helium atoms have a typical thermal velocity of maybe ~2km/s, and the escape velocity is ~11km/s. e^(-5.5) is still significant, therefore some helium atoms can escape.
Jul31-12, 07:21 PM   #12
Gases do behave as fluids; Gases are fluids.
Aug1-12, 03:56 AM   #13
krd
Come on, you're really stretching it. They are two different states. They may have characteristics that overlap, but they are not the same thing.
My understanding of the states
Plasma: Highly energised particles explosively trying to escape in all directions. Like a gas, but simultaneously unlike a gas.
Gaseous: Energised particles with a great deal of free movement. They can exhibit pseudo-fluid characteristics, like the laminar flow of smoke from a cigarette. In the laminar flow, the particles can be considered to be weakly bound (they are not in fact bound) At lower temperatures/particle momentum, the molecules will become bound by Van der Waal forces and condense into liquid state.
Liquid: Lower energy/momentum particles. With freedom of movement, but held together by a stickiness of Van der Waal forces on some particles. (Some particles are stuck together others are free moving - the state is maintained by particles being bound and then knocked free from their bounds by other particles - the state is maintained as long as their is enough momentum in the particles to keep breaking the Van der Waal bonds - for the liquid to become a gas, the VdW bonds must be completely overwhelmed).
Colloid : A state between liquid and solid. Not exhibited by all materials. Custard is a colloid. Colloids have some of the characteristics of both solids and liquids, but not others.
Solid : Lowest energy. When the net Van der Waal forces in a liquid overcome the momentum of unbound particles, crystal nucleation of large groups of particles is allowed. If the crystallisation continues, particles are left with little freedom of movement - they are fixed in position and can only vibrate.
The thing is, all the states are just particles at different net energies - it's all the same thing, except it isn't. It's really how you want to define it. Deuterium Oxide and briny water will sink to the bottom of the ocean, but it does not mean you will not find salt and deuterium near the surface.
Aug1-12, 04:05 AM   #14
krd
No. think about what's happening on an atomic scale. When you release the helium and the atoms start to climb, they will collide with oxygen and nitrogen, giving them momentum to fly off. And even recoil downwards.
The reason a helium filled balloon is buoyant is due to the Archimedes principle. The net effect of the helium in the balloon is it's less dense then the air. You can treat the balloon as a single particle - the net effect of all the free air collisions on the outside of the balloon is to give it upwards momentum. If it was a heavier than air gas, the net effect would be to give the balloon a downward momentum.
Aug1-12, 05:58 AM   #15
Recognitions:
Gold Membership Gold Member
It's common for people to confuse the terms 'liquid' and 'fluid'. Another one that you frequently hear is when people talk of 'opaque glass' when they mean 'obscure glass'.
It 'literally' drives me mad!!!!
Aug1-12, 06:27 AM   #16
krd
Quote by sophiecentaur View Post
You're better off not to confuse people. A gas can be a fluid because it flows. But when people say fluid they generally mean a liquid. Gases can have fluid characteristics but they are not liquids. But you could put that the other way, liquids share characteristics with gases - but that doesn't make them gases.
A colloid is a fluid. Because it can flow, but it is neither a solid, a liquid, nor a gas. Generally, referring to a colloid as a fluid, in context where the specific characteristics of the colloid are important, is incorrect - though it may be right in the literal sense, it's the wrong thing to do.
Plus, playing Gotcha!!! is just being a smart arse. No one calls a gas a fluid outside of specific context, unless they're playing Gotcha!!!.
Aug1-12, 06:46 AM   #17
Recognitions:
I take your point to some extent but PF is surely supposed to be more than just "people" and it's not the world of 'Pub Chat'. We are surely supposed to be discussing and explaining things in formal terms and trying to avoid confusion. When a word is used here, it should be in its properly defined sense or where would we be in discussing a topic like Electricity, for instance.
Archimedes' Principle refers to 'a fluid' and it works for hot air balloons as well as for boats. The "specific context" on PF is Physics. It isn't playing 'gotcha' here; it's spelling things out to avoid misconceptions and misunderstandings. I wouldn't pick holes in an instruction over a hospital bed which said "Check fluid intake" because we would all expect the patient to continue to breathe, unmonitored. That's a different world.
Thread Closed
Thread Tools
Similar Threads for: inside a container with non-pure helium
Thread Forum Replies
how to keep stable temperature inside an iron container of mm thin Atomic, Solid State, Comp. Physics 1
How pressure inside container reacting on bolts. Introductory Physics Homework 0
Rate of radiation coming from inside a container Introductory Physics Homework 1
Electron Inside the Nucleus on Helium Atoms Problem Advanced Physics Homework 1
Best Way To Create Pressure Inside A Container General Physics 3
