New Reply
FORTRAN 90 Unexpected Statement Function Statement in Nested Do Loop
Share Thread Thread Tools
Aug2-12, 12:45 PM   #1
In the following code, highlighted in bold, I am using a nested DO loop to create a running sum of the yearly emissions ("emissions") read out of histem.txt, to create a cumulative emissions curve.
The code generates an "Unexpected STATEMENT FUNCTION statement for sum in cem(i) = sum, however?
Code:
program sat_profile
! This program can be used to create a smooth temperature profile starting from
! a specified slope at the year 2005 and stabilizing (with zero slope) at 2300.
! The starting slope can be calculated from the last 10 years of the simulation
! providing the initial condition at 2005. A starting temperature and final
! temperature also need to be specified. The final target temperature should be
! the modelled preindustrial temperature plus the temperature target (1.5, 2, 3,
! and 4 degrees C). An arbitrary mid point year and temperature (between 2005
! and 2300) is also specified. This may need some adjustment in order to
! generate a smoothly changing profile without overshoot. The output is a text
! file with annual values from 2005 to 2500. This can be adjusted to provide
! interpolated values at other time intervals by changing the loop that
! generates tval and calculates yval.
 implicit none
  integer, parameter :: nd=3, iyr=2008, fyr = 2500
  integer i, j
  real t(nd), y(nd), ypp(nd), tval, yval, ypval, yppval, ybcbeg, ybcend, offset, initg
  real year(257), emissions(257), HIST, TIM, sum, cem
  real AEMIT(iyr:fyr), EMIT(iyr:fyr), TIME(iyr:fyr)
! input parameters: NOTE --> t(1) and t(3) MUST match iyr and fyr respectively
  t(1) = 2008.               ! starting year of synthetic profile
  t(3) = 2500.               ! year of zero emissions
  t(2) = 2400.               ! year of peak emissions (may be adjusted)
  y(1) = 346.758            ! emissions at starting year (set to year 2008)
  y(3) = 2000          ! emissions at end (set to PI + target)
  y(2) = 1900      ! emissions at peak (may be adjusted)
! starting slope can be derived from the last 10 years of a simulation to 2008
  initg =  8.749	     ! value of EMIT(t=1) (should be the same as 2008 annual emissions in historical curve)
  ybcbeg = 8.749           ! slope at t(1) (Gt year-1)
  ybcend = 0.                ! slope at t(3) (zero)
  offset = 0               ! time offset (half of the averaging period)
! calculate the spline derivatives
  call spline_cubic_set ( nd, t, y, 1, ybcbeg, 1, ybcend, ypp )
if (t(3).lt.t(2)) then
print *, 'error, t(2) must be smaller than t(3)'
call exit(1)
endif
if (t(3).eq.t(2)) then
call exit(1)
endif
if (iyr.ne.t(1)) then
print *, 'error, iyr and t(1) do not match'
call exit(1)
endif
if (fyr.ne.t(3)) then
print *, 'error, fyr and t(3) do not match'
call exit(1)
endif
open(unit=15, file='histem.txt')
read(15,*,end=258) year, emissions
258 open (10, file='cumemC.txt')
! evaluate the spline at points tval
!change 2005, 2500 to values of t(1) and t(3)
do i=1,257
sum=0
     do j=1,i
     sum = sum + emissions(j)
     write (*, '(2f12.4)')
     enddo
cem(i) = sum
write (10, '(2f12.4)') year(i), cem(i)
enddo
do i=iyr,fyr
    tval = float(i)
    call spline_cubic_val ( nd, t, y, ypp, tval, yval, ypval, yppval )
! if not doing stabilization, get rid of this line:
    !if (tval > t(3)) yval = y(3)
if (tval.eq.t(1)) yval = y(1)
  write (*, '(2f12.4)' ) tval+offset, yval
  write (10, '(2f12.4)' ) tval+offset, yval
    AEMIT(i) = yval
    TIME(i) = tval
  end do
close (10)
open(10, file='anemC.txt')
write (10, '(2f12.4)') year, emissions
 EMIT(iyr) = initg
write (*, '(2f12.4)' ) TIME(iyr), EMIT(iyr)
    write (10, '(2f12.4)' ) TIME(iyr), EMIT(iyr)
 do i=iyr+1,fyr
  EMIT(i) = AEMIT(i) - AEMIT(i-1)
  write (*, '(2f12.4)' ) TIME(i), EMIT(i)
    write (10, '(2f12.4)' ) TIME(i), EMIT(i)
  end do
close (10)
end
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Aug2-12, 01:03 PM   #2
Mentor
Change the name of your 'sum' variable. It's colliding with an intrinsic function - see http://gcc.gnu.org/onlinedocs/gfortran/SUM.html.
Aug2-12, 01:16 PM   #3
Recognitions:
The immediate issue is that "cem()" is being used as an array but is not declared as such.
Aug2-12, 05:41 PM   #4
Thanks!
I have now found that my read statement is going to cause some trouble too!
Looks like I am reading in year and emissions each as a one dimensional array, and then trying to re-write them as a scalar entity.
Aug2-12, 05:44 PM   #5
Quote by uart View Post
Thanks!
Looks like I am reading in year and emissions each as a one dimensional array, and then trying to re-write them as a scalar entity?
New Reply
Tags
fortran, fortran 90, nested do loop
Thread Tools
Similar Threads for: FORTRAN 90 Unexpected Statement Function Statement in Nested Do Loop
Thread Forum Replies
Nested if statement within a do-while loop Programming & Comp Sci 18
Fortran 77 DECK statement Programming & Comp Sci 6
Unclassifiable statement,, Unexpected data declaration statement Programming & Comp Sci 3
Help! -Negate statement then reexpress as equiv positive statement Calculus & Beyond Homework 1
Nested If statement:: Simple but what Am I missing? Programming & Comp Sci 6
