2 masses collide, one has spring. -Collision, Momentum, Spring energy
The problem involves a collision between two masses, where one mass has a spring attached. Mass 1 is moving at 10 m/s and collides with mass 2, which is initially at rest. The spring has a stiffness of 200 N/m and a natural length of 0.1 m. The goal is to determine the compression (delta X) of the spring at the moment of maximum compression during the collision, while considering conservation of momentum and mechanical energy.
  • Mixed
  • Participants discuss the conservation of momentum and energy, attempting to set up equations to relate kinetic and potential energy. There are questions about the arrangement of the spring and whether the compression can exceed its natural length. Some participants express confusion about the signs and units in their calculations.
Participants are exploring different aspects of the problem, including the setup and the implications of their calculations. There is acknowledgment of potential issues with the values obtained for delta X, particularly regarding the physical constraints of the spring's compression. Some guidance is offered on the need for clarity in the arrangement of the masses and the spring.
There are concerns about the clarity of the problem setup, particularly regarding the orientation and connection of the spring. Participants note that the calculated compression should not exceed the natural length of the spring, which adds complexity to the discussion.
azurken
Mass 1 at 10m/s collides into mass 2 at rest, which has a spring attached to it. The second mass has a spring at 200N/m and natural length L0 = 0.1m. At the instant they collide, the spring is compressed to its max amount and the masses move with the same speed V. Determine the delta X between the objects at this instant. Both momentum and mech energy are conserved.
M1=0.4kg
M2=0.8kg
V1=10 m/s
V2=0 (at rest)
K= 200N/m
L0=0.1m
dX=??
Vf=(m1v1+m2v2)/(m1+m2)
SPE=0.5Kx^2
KE=0.5mV^2
dX=L-L0
Vf=(.4)(10)/(1.2)=3.333
So there are three instances here of the collision, when the m1 goes to m2 is the first. Then M1 and M2 being the same object at that one instant. And after. I don't need to measure after so I can just do.
KE1+PE1=KE2+PE2
which gives me KE1=.5*m1*v1^2
No contact made at PE1 so there's none here.
KE2 = (.5)*(m1+m2)*(Vf)^2
Then PE2 and at this point there's contact and since I know it's compressing the Delta X should be negative (which is still strange) when it all works out.
PE2 = (.5)*(200N/m)*(dX)^2
All this will give me KE1=KE2+PE2 to
20m/s = [6.666(Kg)(m^2)/(s^2)] + (.5)*(200N/m)*dX^2
20m/s - [6.666(Kg)(m^2)/(s^2)] = (.5)*(200N/m)*dX^2
.2 m/s - 0.666 (kgm^2)/(s^2) = dX^2
Yes the units don't match up. I can't clear it but if I ignore all that, a -(.466) sqrooted is -.683 as the dX.
Alright so yeah. After doing a couple other trials, I'll basically get numbers larger than the L0 (natural length) for dX. Which can't be true because it can only compress so much. It cannot be more than 0.1m.
The arrangement is not clear. Is the spring connected to anything else? What is the orientation of the spring with regard to the other mass? A picture would help immensely.
M1=0.4kg
M2=0.8kg
V1=10 m/s
V2=0 (at rest)
K= 200N/m
L0=0.1m
dX=??
SPE=0.5Kx^2
KE=0.5mV^2
dX=L-L0
KE1+PE1=KE2+PE2
You have calculate KE1 in bold.
Then why change the unit?
  • · Replies 16 ·
  • · Replies 22 ·
