How to solve this system of Differential equation
This discussion focuses on solving a non-linear system of differential equations using MATLAB. The equations involve variables y1, y2, and y3, with conditions for F and B based on the values of y3 and C7. The recommended approach is to utilize the Runge-Kutta 4th order (RK4) method, implementing F and B as Heaviside functions to handle the non-linearity. The user is encouraged to share their MATLAB code for more tailored assistance.
  • Understanding of non-linear differential equations
  • Familiarity with MATLAB programming
  • Knowledge of numerical methods, specifically Runge-Kutta methods
  • Concept of Heaviside functions in mathematical modeling
  • Research MATLAB's ODE solvers, particularly ODE23 and its applications
  • Learn about implementing Heaviside functions in MATLAB
  • Study the Runge-Kutta 4th order method for numerical solutions
  • Explore best practices for debugging MATLAB code related to differential equations
Mathematicians, engineers, and researchers working with differential equations, particularly those utilizing MATLAB for numerical simulations and modeling non-linear systems.
revooridinesh
I have equations as
C1*y1' = F*C2*y2 - C3*y1
y2' = C4 -B* C5*y3 - C6*y1
y2-C7=x(t)*y3
X(t) is a known function
where F = 0 when y3<y1
1 when y3>y1
B=0 when C7<y3
1 when C7>y3
C's are constants
so what I am thinking is at time t1 i will get the values for F and B depending on previous values and X value will be known and I need the solution for the unknowns at time t1. I tried solving this by Newton raphshon method but the solution is not converging. Are there any MATLAB commands for this like ODE 23 OR any new solution is welcomed
Thanks a lot
Hey revooridinesh and welcome to the forums.
This is definitely a non-linear system of DE's so you won't be able to use something like an integral transform as easily.
What I recommend is if you use MATLAB, you use a scheme like say RK4 and then implement your F and B functions as Heaviside functions.
The idea is that you have a function representing the derivative of all your functions (y1,y2,y3) as a function of the current values of each function. You then use a scheme (like RK4, but it could be any decent numerical scheme) to get the new values at some later step-size.
If you are using MATLAB, maybe you should show us what your code is doing so people can make specific comments on it.
  • · Replies 0 ·
