Question regarding biot savart law and magnetic fields from current
The discussion revolves around the implications of the Biot-Savart law and magnetic fields generated by a moving charged wire, particularly in different reference frames. Participants explore the relationship between electric and magnetic fields, the effects of relative motion, and the necessity of special relativity in resolving these issues.
  • One participant describes a scenario involving a long straight wire with a stationary charge that moves with the wire, questioning the presence of magnetic fields in different reference frames.
  • Another participant suggests that the concern about different forces in different frames cannot be resolved without special relativity, as forces are not invariant under Galilean transformations.
  • A participant asserts that if there is no relative motion with respect to the charges in the wire, no magnetic field will be experienced, while motion will result in a magnetic field.
  • One contributor emphasizes that the existence of the magnetic field depends on relative velocities, indicating a connection to special relativity and the unification of electric and magnetic fields through the electromagnetic field tensor.
  • Another participant provides transformation equations for electric and magnetic fields between stationary and moving frames, noting that the presence of a magnetic field in one frame can lead to different forces in another frame.
  • There is mention of classical explanations involving Maxwell's equations and changing fluxes, although the necessity of special relativity is acknowledged.
Participants express differing views on whether the scenario can be resolved using classical mechanics or if special relativity is essential. There is no consensus on a definitive resolution to the problem posed.
The discussion highlights the limitations of classical mechanics in addressing the effects of relative motion on magnetic fields and the necessity of special relativity for a complete understanding. Some assumptions about the nature of forces and fields in different frames remain unresolved.
bigerst
say you have a very very long (or infinite) straight wire the carried a charge (glued to the wire) and the wire moves forward with speed v with respect to reference frame S, this creates a current, which according to the Biot Savart law creates a magnetic field. But in reference frame S' relatively stationary to the wire since the charges are not moving there is no current and hence there is no magnetic field. suppose a statinary charge is placed at the origin of S', in S' the charge experiences no magnetic force but in S it does?
i haven't really done special relativity yet so can someone resolve this in terms of classical mechanics (assuming v <<c)?
Is your worry that the same charge can experience different forces measured in different reference frames? In non-relativistic mechanics (Galilean transform) force is the same in inertial frames moving at constant relative velocity. So you can't, imo, resolve your problem without using Special Relativity theory – when it all comes clear.
May have misunderstood your problem. Others are bound to respond: this topic is a perennial favourite.
if you have 0 relative motion with respect to the charges in the wire you will experience no magnetic field. if the relative motion is not 0, you will experience a magnetic field
You're correct bigerst, the moving frame (S') will not have a magnetic field present. The fact that the very existence of the magnetic field depends on relative velocities screams out special relativity. The big result from applying special relativity to electromagnetism is the uniting of the electric and magnetic fields as one in the same object that transforms from one moving frame to another in a specific way (the "object" that contains both the electric and magnetic field that "unites" the two is called the electromagnetic field tensor, but I don't really want to get into it because of the mathematical sophistication. Just know that it has six components and obeys the 6 transformation equations I list at the end of this post.) In fact, if you allow the S' frame to be moving at constant velocity in the 'x' direction, you get the following equation that relates the fields in the S (stationary) frame to the S' (frame traveling in uniform translational motion in the 'x' direction):
[itex]\begin{split}<br /> {E}_{x'} &= E_{x} \\<br /> {E}_{y'} &= \gamma (E_{y} - v B_{z}) \\<br /> {E}_{z'} &= \gamma (E_{z} + v B_{y}) \\<br /> {B}_{x'} &= B_{x} \\<br /> {B}_{y'} &= \gamma (B_{y} + \frac{v}{c^2} E_{z}) \\<br /> {B}_{z'} &= \gamma (B_{z} - \frac{v}{c^2} E_{y})<br /> \end{split}[/itex]
Here 'v' is the velocity and [itex]\large \gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}[/itex].
You can sort of "play" around with these transformation equations to get a better feel of what they really mean. Specifically, look what happens when you have no magnetic field in the stationary frame (the un-primed frame) and you want to know what kind of magnetic field you gain in a moving frame (the primed frame). You can only gain a magnetic field that is transverse to the direction of motion (because [itex]B_{x'} = B_{x}[/itex] and [itex]B_{x} = 0[/itex]). Just things like that are fun to notice (you can thus see why the Biot-Savart law produces field in the directions it does..)
Edit*** I guess I should say that to respond to your apparent "discrepancy", if you place a charge in the S' frame so that it's stationary according to an observer in the S' frame, it will indeed produce a magnetic field for the stationary S frame. The magnetic force will be different, but so will the force from the electric field!
Also this can be explained "classically" from Maxwell's equations I'm sure (though special relativity is implicit in them anyway..), but I haven't thought of how to do this yet. I may come back to this.
Edit again*** Yeah, you can just say that there are transverse planes traveling along with the moving charge that experience a changing flux because the charge is moving closer or further from those planes at speed 'v'. Changing fluxes produce fields from Faraday and Ampere's Laws:
[itex]\begin{split}<br /> \nabla \times \vec{E} &= - \frac{{\partial}{\vec{B}}}{{\partial}{t}} \\<br /> \nabla \times \vec{B} &= \mu_{o} \vec{J} - \mu_{o} \epsilon_{o} \frac{{\partial}{\vec{E}}}{{\partial}{t}}<br /> \end{split}[/itex]
That's a "classical" explanation..
thanks. it helps
  • · Replies 0 ·
  • · Replies 27 ·
