[C] select() won't stop responding to read from client
  • Thread starter Thread starter zeion
The discussion centers on the issue of the select() function in a C server application continuously responding to a client due to not properly reading data from the file descriptor (fd). The user reports that select() returns the same client fd repeatedly, causing the server to spam responses. The solution involves ensuring that all available data is read from the fd, as select() indicates that data is present, not that it has been processed.
  • Understanding of C programming language
  • Familiarity with socket programming concepts
  • Knowledge of the select() system call
  • Experience with file descriptors in Unix/Linux environments
  • Research how to properly read data from a file descriptor in C
  • Learn about handling multiple clients using select() in socket programming
  • Explore the use of non-blocking sockets to manage client connections
  • Investigate the use of epoll as an alternative to select() for scalability
Software developers, particularly those working on network applications in C, and anyone troubleshooting client-server communication issues using select().
zeion
Hi,
So I have written a server that will detect activity by connected clients using select. I am able to detect when a client has typed something from their keyboard, and then it will send send a message to the client in response.
The problem is that select() seems to be returning the same client fd in every iteration. So I would type one character from the client, then the server non-stop spams the client with the response message because it thinks that the client has still typed something.
How do I make it so that select() will only send the response message once and not forever?
I've already tried to remove client FD from the fd list and fflush but they don't do jack.
Technology news on Phys.org
Are you actually reading data from the fd, and all of it?
If not, then select is doing exactly what it's supposed to do: it's telling you there's data there to be read.
13K
11K
