Are superconductivity and melting not understood?
The discussion revolves around the understanding of melting as a phase transition and superconductivity, particularly the limitations of BCS theory in explaining high-temperature superconductivity. Participants explore the complexities involved in both phenomena, questioning the completeness of current theories and models.
  • Some participants suggest that while melting can be described thermodynamically, a complete microscopic understanding remains challenging due to the complexities of short-range order in liquids and the role of defects.
  • Others argue that BCS theory adequately explains standard superconductivity but does not fully account for high-temperature superconductors, raising questions about the underlying mechanisms.
  • A participant mentions that the difficulties in describing melting extend to higher dimensions, citing a specific review article on 2D melting as an example of the challenges faced in understanding these phase transitions.
  • There is a clarification regarding the types of high-temperature superconductors, specifically mentioning cuprate and pnictide superconductors.
Participants express differing views on the completeness of the understanding of melting and superconductivity. While some find the explanations satisfactory, others highlight significant gaps and complexities that remain unresolved.
The discussion acknowledges that the understanding of melting and superconductivity may depend on specific definitions and contexts, and that computational challenges exist in modeling these phenomena accurately.
VortexLattice
Hi all,
I've been told from a couple different people something along the lines of "we don't fully understand how melting (the phase transition) works". Same with superconductivity.
But I thought melting was fairly straightforward: The molecules in the material keep gaining energy until they break free from their crystal intermolecular bonds, and then they have some weaker bonds holding them together.
I also thought superconductivity was explained by BCS theory.
Is there any truth to this? I assume if there is, it's something much deeper and more mathematical, and that we have the general idea but there's still something more technical not understood.
The BCS theory works for standard superconductivity, but not high temperature superconductivity. (Or it at least doesn't fully explain high temp SC)
As for melting, I have never heard anyone say that before.
It is not that trivial. While describing melting from the thermodynamical point of view works reasonably well, a microscopic description of what is happening is significantly harder if you want all the details to be reproduced well. For examle liquids do not show long-range order like crystals, but are typically not completely disordered as well - they show short-range order. Trying to get this and similar effects from first principles is a major pain and takes long computation times. The role of defects may also be crucial.
See for example U. Gasser et al., "Melting of Crystals in Two Dimensions", ChemPhysChem, Volume 11, Issue 5, pages 963–970, April 6, 2010 for a review article.
You will find: 2D melting is already hard to describe - 3d melting may become a nightmare.
Sorry, "high temp" being the ones that can work in LN2, or fabled room temp ones?
Ah, I think this is what they meant. For a bit I was looking at a colloids lab that was trying to figure out melting in 2D using small, mechanical beads or something.
These are the cuprate and pnictide superconductors.
Zz.
