Tetrahedrally adapted d-orbitals?
  • Context: Graduate
  • Thread starter Thread starter osskall
The discussion revolves around the shapes of tetrahedrally adapted atomic d-orbitals and their interactions in a tetrahedral ligand field. Participants explore the relationship between d-orbitals and their hybridization, as well as the implications for molecular orbital theory and crystal field theory.
  • Some participants inquire about the shapes of tetrahedrally adapted d-orbitals and whether the familiar d-orbitals represent all possible shapes.
  • There is a discussion on the ability of a triply degenerate set of d-orbitals to interact with ligands in a tetrahedral field, contrasting this with octahedral symmetry where the interaction is reversed.
  • One participant suggests that linear combinations of d-orbitals could yield a doubly and a triply degenerate set in a tetrahedral field.
  • Another participant mentions hybridization and its relation to X-ray diffraction data, suggesting resources like Density Functional Theory (DFT) for further exploration of orbital shapes.
  • There is a mention of the relationship between d-orbitals and p-orbitals, proposing that mixing odd wavefunctions may yield more tetrahedral-like shapes.
  • Some participants express uncertainty or confusion regarding the application of DFT and its relation to the Bohr model.
  • One participant notes the dependence of d-orbital orientations on the crystal field, affecting their energy relative to 2p orbitals.
Participants express a range of views on the nature of d-orbitals in tetrahedral fields, with no consensus reached on the specifics of their shapes or interactions. Some points remain contested, particularly regarding the application of hybridization and the implications of DFT.
Limitations include potential misunderstandings of the relationship between d-orbitals and their hybridized forms, as well as the varying interpretations of DFT and its application in this context.
osskall
Does anyone have a link to a picture of the shapes of tetrahedrally adapted atomic d-orbitals?
Aren't the familiar d(z2), d(x2-y2), d(xz), d(xy) and d(yz) orbitals just one of several possible sets of atomic d-orbital shapes? Or have I misunderstood this point?
I would like to rationalise why in a tetrahedral ligand field a triply degenerate set will be able to interact with the ligands and a doubly degenerate set will not. For octahedral symmetry this (well, rather the inverse: two orbitals interact, three won't) is easy, because usually we depict the d-orbitals as above in cartesian coordinates. But shouldn't it be possible to make linear combinations of the d-orbitals to create what is to become one doubly and one triply degenerate set if a tetrahedral field is applied?
I tried the question in the chemistry section, but without much success, when I realized it might be better placed here since it concerns atomic orbitals and quantum physics (although it applies to chemical complex forming and MO theory).
Your talking hybridization when you modify the d orbitals to match the XRD data. You might find some ideas if you visit: www.orbitals.com .
The guys here prefer to look at wave functions and would probably refer you to check a theory called Density Functional Theory (DFT) which might provide orbital-like images, but I'm not sure. You might also check for a software called "Schrödinger". Have not used that soft for a while, so I might have to revise the name. Will check a web search.
Just to be correct : QM delivers all knowledge on atomic orbitals (the squared spherical harmonics) as well as hybridization. I am sure you have heard of these harmonics and their use in molecular orbital theory. The idea is the write the wavefunction of a molecule as a linear combination of the constituent atomic wave functions, provided to us by solving the eigenequation for both L² and L_z-operators.
DFT is used to solve the Schrödinger equation (SE) in an approximative manner. The idea is to look at many interacting electrons as if they are all free and moving in a new socalled effective potential. This is basically the same as Hartree Fock states but in DFT you start from an arbitrary expression for the electron density and you determin the groundstate energy of the many particle system. In hartree Fock theory, you start from an arbitrary guess for the electron-wavefunction. By using the variational principle you can determin an upper limit for the system's ground state energy. Keep in mind that in DFT every observable (energy and so on) is written as a functional of the electron density because you can proove there is a 1-1-relation between the wavefunction of the system and the electron density. This is the Hohenbergh-Kohn-Theorema...
regards
marlon
Hm...Ain't it a bit weird:what_are_electrons mentions DFT,yet he's pretty unclear with the Bohr model...
C'est la vie...
Daniel.
Yes, but are not these just the d_xy, d_xz, d_yz etcetera?
If you want something that looks more tetrahedral, you need to mix in odd wavefunctions: 3p-orbitals. "Atom in a Box" at http://daugerresearch.com/orbitals/ can show you the orbitals. Actually, there is a tetrahedral example on the page: a superposition of <3,2,1> and <3,1,-1>.
Hälsningar & groeten,
/Pieter
depending on the cyrstal field the d orbitals are going to point in different directions. Changing the energy relative to the 2p orbitals. Aso you get a difference in the bonding of the [itex]d\gamma[/itex] and [itex]d\varepsilon[/itex] with the p orbitals.
C'est la vie...
Daniel.
Hey... I read that!
BTW, I'm not the one making unsubstantiated correlations. Just 'cause I ask a question ...
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 31 ·
13K
