Thermal Equilibrium between a Hot and Cold Body
The discussion centers on thermal equilibrium between a hot body and a cold body in closed systems. When these bodies are in contact, thermal energy transfers from the hot body to the cold body through conduction until thermal equilibrium is achieved. Although the overall temperature remains constant, the molecules within the combined systems do not share identical kinetic energy, leading to continuous collisions and energy exchanges. This process is thermodynamically irreversible, resulting in a Boltzmann distribution of energies, specifically a Maxwell-Boltzmann distribution for gas molecules.
  • Understanding of thermal energy transfer and conduction
  • Familiarity with the concept of thermal equilibrium
  • Knowledge of kinetic energy and its relationship to temperature
  • Basic principles of thermodynamics and statistical mechanics
  • Study the principles of thermodynamic irreversibility
  • Explore the Maxwell-Boltzmann distribution in detail
  • Learn about the implications of thermal equilibrium in closed systems
  • Investigate the relationship between temperature and kinetic energy in gases
Students of physics, thermodynamics enthusiasts, and professionals in fields involving heat transfer and statistical mechanics will benefit from this discussion.
hwall95
Just a quick question relating to thermal equilibrium between a hot and cold body. If a hot body and cold (closed systems) are opened up to each other, the thermal energy will be transfer from the hot body to cold body through conduction. So even when thermal equilibrium is reached, the temperature may be constant (closed system) but the molecules within combined bodies do not all contain the same kinetic energy right? So they will continue to collide and gain and lose kinetic energy for infinity basically right even though the overall temperature remains constant? Sorry I am just trying to make sure I'm not making incorrect conclusions.
Any help would be greatly appreciated, thanks :)
Science news on Phys.org
Yes I think I understand what you are asking.
The average kinetic energy of the molecules is closely related to temperature so will never be zero except at absolute zero. As with all averages it is a bulk composite of a range of values.
Incidentally if you allow heat transfer by direct contact, as you describe, the process is thermodynamically irreversible.
You will end up with a Boltzmann distribution of energies in each accessible degree of freedom. For gas molecules, this will give a Maxwell-Boltzmann distribution of translational kinetic energies.
  • · Replies 19 ·
  • · Replies 135 ·
10K
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 35 ·
