Calculating Charges of Two Small Nonconducting Spheres
  • Thread starter Thread starter Soaring Crane
    Charges Spheres
The discussion focuses on calculating the charges of two small nonconducting spheres with a total charge of 80 microC and a distance of 1.06 m between them. The repulsive force between the spheres is 12 N, leading to the equation derived from Coulomb's Law: F = k(Q1Q2)/r². The participants confirm the correct approach involves solving a quadratic equation formed by substituting Q1 + Q2 = 8 x 10^-5 C and Q1Q2 = 1.498 x 10^-9 C. If the force were attractive, the sign in the equation changes, resulting in a different quadratic equation.
  • Coulomb's Law
  • Quadratic equations
  • Basic electrostatics concepts
  • Understanding of nonconducting materials
  • Learn to apply Coulomb's Law in various scenarios
  • Study the quadratic formula and its applications in physics
  • Explore the properties of nonconducting materials in electrostatics
  • Investigate the effects of distance on electrostatic forces
Students and educators in physics, particularly those studying electrostatics, as well as anyone interested in solving problems involving electric charges and forces.
Soaring Crane
Two small nonconducting spheres have a total charge of 80 microC. When place 1.06 m apart, the force exerts on the other is 12 N and is repulsive. What is the charge of each. What if the force were attractive?
Given: k, F = 12 N if repulsive but F = -12 N if attractive, Q1 + Q2 = 8 x 10^-5 C, r = 1.06 m
Using Coulomb’s Law, isolate Q1Q2 .
Q1Q2 = 1.498 x 10^-9 C?
Then I thought I would use substitution for Q1 + Q2 = 8 x 10^-5 C and Q1Q2 = 1.498 x 10^-9 C.
But now I get a huge quadratic equation. Is this the correct method??
Thanks.
Your method is correct. You have to solve the qudratic to find Q1, Q2. There really isn't a better way.
Yes, you are on the right track! To solve for the individual charges of each sphere, you can use the following equation:
F = k(Q1Q2)/r^2
Substituting in the given values, we have:
12 N = (8.99 x 10^9 Nm^2/C^2)(Q1Q2)/(1.06 m)^2
Solving for Q1Q2, we get:
Now, as you mentioned, we can use substitution to solve for the individual charges. We know that Q1 + Q2 = 8 x 10^-5 C, so we can rewrite the equation as:
Q1 = (8 x 10^-5 C) - Q2
Substituting this into the equation for Q1Q2, we get:
(8 x 10^-5 C - Q2)Q2 = 1.498 x 10^-9 C
Simplifying, we get a quadratic equation:
Q2^2 - (8 x 10^-5 C)Q2 + 1.498 x 10^-9 C = 0
Using the quadratic formula, we can solve for Q2 and then plug that value back into the equation for Q1 to find its value.
If the force were attractive, we would simply change the sign in the equation for F, so we would have:
-12 N = (8.99 x 10^9 Nm^2/C^2)(Q1Q2)/(1.06 m)^2
Q1Q2 = -1.498 x 10^-9 C
Using the same substitution method as before, we get the quadratic equation:
Q2^2 + (8 x 10^-5 C)Q2 + 1.498 x 10^-9 C = 0
Solving for Q2 and then plugging that value back into the equation for Q1, we can find the individual charges for an attractive force.
I hope this helps clarify the process for solving this problem. Keep in mind that the quadratic equation may seem intimidating, but it is a common method for solving problems involving two unknown variables. Good luck!
