| New Reply |
Pulley system (ideal pulley) Find the angle with vertical line |
Share Thread | Thread Tools |
| Aug9-12, 06:19 AM | #1 |
Ideal pulley and strings, no friction.The pulley and the second string don't move.
I need to find the numerical value of theta, the acceleration of the two blocks and the tensions.Accelerations and tension must be given in terms of m and g. I guess 2T1=T2 T1=m2*a m1*g-T1=m1*a To find theta I need to know the angle between T2 and T2*cosθ. Are these equations correct?What is missing? |
| Aug9-12, 07:57 AM | #2 |
Recognitions:
Hi thirteenheath, welcome to PF.
T2, the tension in chord 2 is not parallel with the forces of tension (T1, one horizontal and one vertical), chord 1 exerts on the pulley. Add them as vectors to get the force on the pulley. As the pulley does not move, the resultant of the tensions must be zero. You can eliminate T1 from the last two equation and get the acceleration of the blocks. ehild |
| Aug16-12, 03:07 PM | #3 |
Thanks ehild!
Oh I see...So if I understood we'll have T1=T2*cosθ T1=T2*sinθ Then cosθ=sinθ and θ=45°. Plus, through the last two equations in the previous post we find that a=m1*g/(m1+m2). Now I just need to replace the acceleration in any of the previous equations to find the values of T1 and T2. Is that it? Thanks again. =) |
| Aug16-12, 03:33 PM | #4 |
Recognitions:
Pulley system (ideal pulley) Find the angle with vertical lineehild |
| New Reply |
| Tags |
| <p><?php the_tags() |
| Thread Tools | |
Similar Threads for: Pulley system (ideal pulley) Find the angle with vertical line
| Find velocity of hanging block in a pulley system | Introductory Physics Homework | 1 | ||
| Double Pulley Systems/Complex Pulley System Problems | Introductory Physics Homework | 1 | ||
| Pulley system, find the mass | Introductory Physics Homework | 2 | ||
| Find acceleration of a Block within a simply pulley system. | Introductory Physics Homework | 3 | ||
| Find velocity of a pulley system | General Physics | 2 | ||
