Calculating Hydraulic Motor Requirements for Plant-Pulling Device
  • Thread starter Thread starter agriculture
    Hydraulic Motor
This discussion focuses on calculating the hydraulic motor requirements for a plant-pulling device utilizing two steel solid core rubber-coated rollers. The rollers measure 12 inches in length and 2.5 inches in diameter, with a rubber surface width of 9.5 inches, and are designed to exert a pulling force of approximately 5 lbs per plant. The hydraulic motor will be connected to the rollers via spur gears, necessitating precise calculations of torque, power, and RPM to ensure effective operation.
  • Understanding of hydraulic motor specifications and performance metrics
  • Knowledge of torque and power calculations in mechanical systems
  • Familiarity with gear ratios and their impact on rotational speed
  • Basic principles of mechanical design for agricultural equipment
  • Research hydraulic motor torque and power calculations
  • Learn about gear ratio calculations and their effects on RPM
  • Study the principles of mechanical advantage in pulling mechanisms
  • Explore design considerations for agricultural machinery
Engineers, mechanical designers, and agricultural equipment developers seeking to optimize the design and functionality of plant-pulling devices using hydraulic motors.
agriculture
Hi,
I would appreciate if someone can help me figure out this design problem. I am working on designing a device to pull plants from the soil. This device consisting of two steel solid core rubber coated rollers. The rollers will be positioned facing each other and rotates in a way to pull plants upright.
The rollers dimensions are 12in length, 2.5in diameter, weight is 6lbs, and the rubber surface is 9.5in. The rollers have a horizontal grooving to increase pulling.
I will use a hydraulic motor to rotate those rollers. The rotation will be accomplished by using spur gears. The gears will be mounted on each roller shaft to mesh together, while the motor will be mounted directly on one of the rollers shaft.
My question is, how I can calculate the torque, power, and rpm required by the hydraulic motor to rotate those rollers if we assume that the force required to pull one plant from the soil is about 5lbs. Thanks!
Hi,
Anyone can help me figure out how to break down my question. Thanks!
  • · Replies 19 ·
  • · Replies 17 ·
10K
  • · Replies 18 ·
36K
