What would Mars be like with 50% more density?
  • Context: Graduate
  • Thread starter Thread starter willstaruss22
    Density Mars
The discussion explores the hypothetical scenario of Mars having 50% more density, examining the implications for its internal structure, surface conditions, atmosphere, and potential for life. Participants speculate on the physical processes that could lead to such a change and the resulting characteristics of the planet.
  • One participant questions the implications of a denser Mars, suggesting it would have a higher surface gravity and potentially retain lighter gases.
  • Another participant proposes that increasing Mars' density would lead to a hotter core and possibly a magnetosphere, which could affect atmospheric density and surface water retention.
  • Some participants discuss the feasibility of increasing Mars' density, with one suggesting that a giant asteroid collision could theoretically add density but would likely destroy the planet.
  • Alternative scenarios for density increase are proposed, including formation in an iron-rich accretion disk or a significant impact event similar to the one that formed Earth's moon.
  • Concerns are raised about the physical implications of adding material to Mars, with one participant noting that increasing mass typically increases radius, complicating the scenario.
  • A participant humorously suggests a sci-fi scenario where a high-density material could be transported to Mars, discussing the theoretical mathematics behind adding a shell of dense material around the planet.
Participants express differing views on the feasibility of increasing Mars' density and the processes that could lead to such a scenario. There is no consensus on the mechanisms or outcomes of this hypothetical situation.
Participants acknowledge limitations in their assumptions about material composition and the physical processes involved in altering Mars' density. The discussion remains speculative and does not resolve the complexities of the proposed scenarios.
willstaruss22
What would Mars be like if it had 50% more density? Like what would be occurring inside, on the surface and the atmosphere? Would there be no water because of the extra density, hotter core, more atmosphere or any other processes?
Astronomy news on Phys.org
You want to speculate about a hypothetical planet with the same mass as Mars but in a smaller volume at Mars distance from a G2 star?
That would make the radius about 87% what it is now. The surface gravity would be higher and it could hang on to more lighter gasses.
Then the planet would have to have been made of denser materials ... more heavy metals etc. You'd need to find a mechanism for this to happen for such a large body. There are reasons for materials being found in particular ratios.
It'd have a smaller surface area - losing heat slower - but would generate more of it due to nuclear decays (heavier metals right?)
That should give you an idea of what sort of thinking is involved.
What's your specific interest? Or is it just idle curiosity apropos of nothing much?
Increasing the density of Mars by 50% would increase its mass to nearly 20% of Earth mass [compared to about 10% at present]. It would also imply a significant increase in heavy elements in the core, a hotter core, and probably a magnetosphere. These factors would contribute to a denser atmosphere, albeit still well short of the kind of atmospheric density on earth. A modest amount of surface water might be retained under such conditions and, in that case, the prospects for life on Mars would be dramatically improved.
No i wanted to see what would happen if we upped the density of Mars by 50% and kept its radius. I am also fasinated by how this might have theoretically occurred and what this would mean for life on the surface?
There is no good way for this to happen. A giant asteroid collision is a possibility, but, it would basically destroy the planet.
I was thinking of that to and came up with 2 possibles for exoplanets with the same density mass radius as the hypothetical mars.
1 The planet forms in the accrecian disk of a star that is much more iron rich than our sun.
2 the planet has the same impact as thea did with Earth that formed the moon billions of years ago but again much more iron rich.
As now i know that there is no way Mars would receive all the iron to raise its density without destroying the planet. But maybe if it were still molten and #2 happened then the density would go up.
Would that make sense?
Keep in mind that adding material to a planet increases it's radius.
Edit: That is correct isn't it? I know that certain gas giants can decrease in radius if more material is added, but I don't think the terrestrial planets would.
Yeah - it makes more sense to talk about the hypothetical Mars-similar planet than adding material to the actual Mars to up it's density by so much.
For sci-fi some mad scientist could just transport a high density material to Mars... a bucket of neutronium? (Yes I know.)
The added mass need not all appear all in one go - Mars could be intercepted by a very big cloud of dense-material micrometeorites that rain heavy dust down to the surface over A Long Time ... basically plating the planet.
Actually... that sounds like fun:
Back of envelope...
If we add new material density [itex]\rho_n[/itex] in a shell around the existing Mars then the total radius would be given by:
[tex]\frac{3\rho_M}{2} = \frac{\rho_n R^3 - (\rho_n - \rho_M)R_M^3}{R^3}[/tex]
...rearranging:
[tex]R^3 = \frac{2(\rho_n - \rho_M)}{2\rho_n - 3\rho_M}R_M^3[/tex]
[note: I think something is wrong with this - if ρn→ρM the shouldn't R→∞ ? But it seems to behave itself for high densities...]
Some figures:
[itex]R_M = 3397\text{km}[/itex]
[itex]\rho_M = 3.93\text{g cm}^{-3}[/itex]
Iron:
[itex]\rho_{Fe} = 6.96\mathbb{g cm}^{-3} \Rightarrow R = 4813\text{km}[/itex]
... which would be a 1500km iron shell.
Chengdeite:
[itex]\rho_{Ir_3 Fe}=19.3\text{g cm}^{-3}\Rightarrow R = 3556\text{km}[/itex]
... for a mere 150km shell of quite pretty rock.
Osmium:
[itex]\rho_{Os}=22.59\text{g cm}^{-3} \Rightarrow R = 3522\text{km}[/itex]
... 126km shell of the densest stable element.
Neutronium: (this should nail it!)
[itex]\rho_{nu}= 3\times 10^{14}\text{g cm}^{-3} \Rightarrow R = 3397\text{km}[/itex]
... about 6nm thick :)
(As usual I have probably made some basic gaff.)
aside: will PFLatex do planet symbols?
  • · Replies 17 ·
  • · Replies 42 ·
