Floating Rock Raft: New Zealand Questions Answered
  • Thread starter Thread starter pnmeadowcroft
    Floating Rock
The discussion revolves around the floating rock raft recently discovered off the coast of New Zealand, focusing on questions regarding its mass and potential movement or dispersion. Participants explore various calculations and assumptions related to the raft's volume and density, as well as its ecological implications.
  • Some participants inquire about the mass of the floating rock raft and its potential trajectory or whether it will disperse.
  • One participant mentions that there are no published estimates of the raft's total mass since its discovery on August 9.
  • Another participant provides a calculation based on the raft's area (26,000 square kilometers) and an assumed thickness (0.6 meters), suggesting a mass of approximately 3.9 billion tonnes, though they express uncertainty about this figure.
  • Further calculations lead to a revised estimate of 390 tonnes, with participants discussing the density of pumice and the implications of their calculations.
  • Some participants challenge earlier calculations, pointing out errors in unit conversions and assumptions about the raft's thickness and density.
  • One participant introduces the idea of scaling down estimates based on the size of pumice fragments, suggesting that the thickness may not be uniform and proposing adjustments for packing density.
Participants express differing views on the mass of the raft, with no consensus reached on the correct calculations or assumptions regarding thickness and density. The discussion remains unresolved as participants continue to refine their calculations and challenge each other's reasoning.
Participants note that the thickness of the pumice may not be uniform across the area, and assumptions about density and packing could significantly affect the mass estimates. There are also unresolved mathematical steps and unit conversion challenges that participants are working through.
Individuals interested in ecological impacts of geological phenomena, mathematical modeling, and those seeking to understand the complexities of estimating mass and volume in natural events may find this discussion relevant.
pnmeadowcroft
Can anyone answer a couple of questions about the new floating rock raft off New Zealand ?
How much mass does it contain ?
Where is it headed ? ( or will it disperse ? )
Please post a link, do not make members hunt for the source.
well time for you to try some maths ;)
you have some of the info, and wiki will provide the rest
its 26,000 sqr km x ~ 600mm (0.6metre thick)
wiki gives an example of ~ 0.25 g / cubic cm for pumice
work out the volume from the first 2 measurements then multiply it by the density
watch your values I would suggest get everything into cubic metres rather than trying to work with km, cm etc
Dave
pnmeadowcroft said:
Yeah, 3.9 billion tonnes, but I don't really like that answer much. The picture on this page:
http://en.mercopress.com/2012/08/10/volcanic-pumice-mass-size-of-belgium-floating-off-the-coast-of-new-zealand
shows that the depth is far from uniform.
yup some bad maths there I think ;)
26,000 sqr km = 26,000,000 sqr metres ( 26 million) x 0.6 metres = 15,600,000 (15.6 million) cubic metres
0.25g / 1ccm => 2.5g / 10 ccm => 25g / 100ccm (ccm = cubic cm) 100ccm = 1 cubic metre
25g = 0.025kg
15,600,000 cubic metres x 0.025kg = 390,000 kg = 390 tonnes ( 1 Tonne = 1000kg)
some one check my maths please :)
Dave
25g = 0.025kg
Dave
Those numbers aren't right. I reckon:
26,000 sqr km = 26,000,000,000 sqr metres
0.25g / 1ccm = 250 kg/m3
EDIT: Imagine a cubic metre of rock. Now how much does that weigh? 25 grams? No way!
crap, I really screwed up my calcs.. doh... I'll bow to your better maths, no wonder I failed school cert maths twice haha
after using some online convertors I agree with your m2
I will work on the rest as well
Dave
using online calculators
gosh am getting such huge numbers its freaky haha
I need to work through this for my own understanding/sanity please correct me if I go wrong
so 10,000 cm2 = 1 metre2
therefore 10,000 x 10,000 x 10,000 cm = 1 m3
now here's something that has always caught me out...
thats 1 with 12 0's is that the same as 1 x 1012 or 1 x 1011 ... I was thinking 11
Dave
Dave
Hi Dave
1 m = 100 cm
1 m2 = m * m = 100 cm * 100 cm = 10,000 cm2
You got that bit right.
Next:
1 m3 = m * m * m = 100 cm * 100 cm * 100 cm = 1,000,000 cm3
You slipped up with that bit.
Incidentally: 1 with 12 0's is the same as 1012.
This stuff is not really maths. It's just working with units. Try to picture a square metre, then imagine how many square cm would fit inside it, then try to imagine a cubic metre and image how many cubic cm would fit inside it. The maths just drops out of the mental picture.
Cheers
OK thanks
yeah something that will trip me up easily haha
i will continue working through this in this thread because I eventually want to confirm for myself the cubic volume and mass of the pumice ... besides there may be others that learn something too haha
OK so we have 26,000,000,000 metres2 and for an avg let's just pick 0.5 m thick = 13,000,000,000 m3
now the fun of converting 0.25g / cm3 to kg / m3
0.25 x 1,000,0003 (1m3) = 250,000g / 1m3 = 250kg / 1m3
which is what you said earlier, billiards :)
so 13,000,000,000 m3 x 250kg / 1m3 = 3,250,000,000,000 kg = 3,250,000,000 metric Tonnes
OK how did I go that time ? :)
Dave
Dave
good that time :) - I use a depth 0.6 to get the 3.9 billion verse 0.5 to get 3.2
Good but the thickness assumption is probably whacky.
One article says the pumice fragments are golf ball sized.
Now golf balls have a diameter of about 5 cm. So I would scale down your answer by a factor of 10 (dave).
Then there is the issue that this thickness is not uniform over the areal extent. You could make another assumption -- e.g. close hexagonal packing -- to account for the gaps in between the pumice fragments: multiply your answer again by 0.74.
yes agreed, the calcs were for a uniform thickness/density, but at least I finally got my units and maths sorted out haha
D
D
Awesome. Glad to be able to help out
17K
  • · Replies 112 ·
11K
  • · Replies 41 ·
13K
