New Reply
Equilibrium constants Ka, Kc, Kx, Kp and rate constants in reversible reactions
Share Thread Thread Tools
Aug15-12, 01:54 AM   #1
Is the statement Ke=k+/k- valid for all equilibrium constants like Ka, Kx, Kp, Kc? All of the expressions I have found for this statement relate Kc, k+ and k- only.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Aug15-12, 08:43 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by ymhiq View Post
At equilibrium, the rate of the forward reaction must equal the rate of the reverse reaction. If the rates are expressed in terms of activities, then the equilibrium constant will be equal to the ratio of the forward- to the reverse rate constant.
Aug15-12, 09:35 PM   #3
Quote by Chestermiller View Post
Thanks for your reply, I knew that but my doubt is exactly if Ke=Ka=Kc=Kx=Kp=(k+/k-) but in advance I Know that Ka≠Kc≠Kx≠Kp so the statement Ke=k+/k- is valid only valid for Kc according to my findings in literature. What about the others equilibrium constants? Is this statement valid for them If so what would be the differences in order to maintain the fact that Ka≠Kc≠Kx≠Kp?
Aug16-12, 06:48 AM   #4
Recognitions:
So that we are on the same page, please refresh my memory of the definitions of Ka, Kc, Kx, and Kp. Do all of these refer to equilibrium constants for chemical reactions using different concentration parameters (and units)?
Aug16-12, 09:19 PM   #5
Yes, Indeed. All of them are equilibrium constants for chemical reactions.
Kc is the most used. It is based on concentration or molarities. Kc=∏(cj^Sj) where Sj is the stoichiometric coefficient of j chemical compound and Cj is its concentration. Concentration is often written as [j]. It has [mol/volume]^Sj units.
Kp is used in reactions in vapor phase so its defined through partial pressures of j in the vapor phase. Kp=∏(pj^Sj). It has [pressure]^Sj units.
Kx is in terms of mole fractions. It used for liquid phase reactions. Kx=∏(xj^Sj). It's dimensionless.
Ka is the Thermodynamic Equilibrium Constant. By definition Ka=∏(aj^Sj). It's dimensionless.
All of them are different and I don't know if you can use the concept Ke=k+/k- for all of them. If so, what would be the differences?
Aug17-12, 09:16 AM   #6
Recognitions:
Yes, they are all related to one another. Start out by writing KE in terms of activities or fugacities. Then express the activities in terms of concentration times activity coefficient, or fugacities in terms of pressure times fugacity coefficient. This will let you see how the different K's are related, and where the k+ and k- can come in.
Aug22-12, 10:48 AM   #7
Would it be correct if I'd wrote something like: Kc = k+/k- = Ka/[{(ƩCj)^(-ƩSj)}*{∏(P^Sj)}*{∏(∅j^Sj)}] ? Here, P is total pressure and ∅j is the fugacity coefficient of j.
Aug24-12, 10:32 PM   #8
Recognitions:
The easiest way to study this is to assume ideal gas behavior and ideal solutions (no heat of mixing). Start out simple, by relating Kp and Kc. The partial pressure of a species is related to the concentration by p = c RT. Substitute this into the expression for Kp. This should allow you to determine the relationship between Kc and Kp. Starting simple like this is very helpful. Why? If you can't solve for the simplest case, you certainly won't be able to do more complicated cases.
Chet
New Reply
Thread Tools
Similar Threads for: Equilibrium constants Ka, Kc, Kx, Kp and rate constants in reversible reactions
Thread Forum Replies
Are undefined constants valid in trig equations when other constants present? General Math 3
Why are there different rate constants? Chemistry 2
Summing reactions/rate constants Chemistry 2
Rate Constants From Equilibrium Constants Biology, Chemistry & Other Homework 6
rate of reaction, rate constants, and Arrhenius' Equation Introductory Physics Homework 0
