Contradicting conclusions on falling bodies.
The discussion revolves around the concepts of work, energy, and gravitational potential energy as they relate to a body falling from a height. Participants explore the apparent contradiction between the work done by gravity and the conservation of energy during the fall, addressing both theoretical and conceptual aspects.
  • One participant notes that when a body falls, the force of gravity does positive work due to the direction of force and displacement being the same.
  • Another participant references the work-energy theorem, suggesting that an increase in kinetic energy implies positive work has been done.
  • A different viewpoint emphasizes that when considering gravitational potential energy, the work done by gravity should not be counted again, as it is already accounted for in the potential energy conversion to kinetic energy.
  • Some participants clarify that including both the work done by gravity and the potential energy leads to double counting of the same effect.
  • There is a discussion about the relationship between gravitational potential energy and the work done by gravity, with an emphasis on the idea that they are different descriptions of the same phenomenon.
Participants express differing views on how to reconcile the concepts of work done by gravity and the conservation of energy. Some agree on the need to avoid double counting, while others explore the implications of the work-energy theorem. The discussion remains unresolved with multiple competing perspectives.
Participants mention the simplifications involved in using the formula for gravitational potential energy (mgh) and note that it is only approximately true near the Earth's surface, suggesting limitations in the general applicability of their arguments.
This discussion may be useful for students and individuals interested in understanding the principles of work and energy in physics, particularly in the context of gravitational forces and potential energy.
rishch
I was recently thinking about potential energy and I came to two conclusions which contradict each other-
1)When a body is falling from a height, the force of gravity is acting on it in the downwards direction. There is displacement in the downwards direction. So as the force and the displacement are in the same direction, some amount of positive work is done on it.
2)When the same body is falling, the potential energy of the body is converted into kinetic energy and the total energy of the ball remains constant. So that means that no work is being done on it.
So in one case there is positive work while in the other no work. How? What's wrong in my reasoning.Please keep the answers as simple as possible because I'm still in secondary school, and won't be able to understand a highly complicated answer. So please keep it as simple as possible.
By the work-energy theorem, [tex]\frac {1}{2} mv_f^2 - \frac {1}{2} mv_i^2 = W,[/tex]if kinetic energy has increased, then positive work must have been done.
Sure. So the kinetic energy increases. (Note that we do not use the concept of gravitational PE here.)
Here we account for the effect of gravity and the work it does by using the concept of gravitational PE.
Using the concept of gravitational PE already includes the effect of gravity, so by counting both the work done by gravity and gravitational PE you end up counting it twice.
Work done by all forces (including gravity) = ΔKE
Work done by all forces (except gravity) = ΔKE + ΔPE
So you're saying that we cannot include the work done by the force of gravity because this work is already included in the potential energy? And for the last sentence where you say "except gravity" that means you are using the concept of PE here?
Right.
Another way to think of it is this:
Work done by all forces (except gravity) + Work done by gravity = ΔKE
Work done by all forces (except gravity) - mgΔh = ΔKE
Work done by all forces (except gravity) = ΔKE + mgΔh
That's basically right, but I would put it a different way: "The force of gravity" and "gravitational potential energy" are really two different descriptions of the same thing. So when you work out the energy change, you shouldn't include the same effect twice.
If a body moves along any path you choose between two fixed points A and B, the amount of work done by the force of gravity is always the same. That means it is possible to define "gravitational potential energy" which depends only on the position of the body in space, and the difference GPE(A) - GPE(B) measures the amount of work done moving between the two points.
If you are still in secondary school you might have only come across a simpler formula that the difference in GPE = mgh, where h is the vertical distance between the two points. That is only approximately true close to the surface of the earth, but the general idea of GPE apples in any situation.
Thanks, I think understand now. And yes, mgh is the only formula I've learnt.
  • · Replies 31 ·
  • · Replies 54 ·
