Increasing Inductance with Iron Core?
  • Thread starter Thread starter amanno
    Inductor
Using a solid ferromagnetic core, such as an iron or steel rod, significantly increases the inductance of an inductor compared to an air core inductor. The increase in inductance can be by a factor of 1000 or more, primarily due to the magnetic permeability of the core material. Permanent magnets should not be used as cores for inductors, as they can lead to magnetic saturation and counteract the magnetic field generated by the coil. Laminated or ferrite cores are recommended to minimize eddy currents.
  • Understanding of inductors and their operation
  • Knowledge of magnetic permeability and its effects
  • Familiarity with magnetic hysteresis
  • Basic concepts of eddy currents in magnetic materials
  • Research the properties of magnetic permeability in various materials
  • Learn about the design and applications of laminated and ferrite cores
  • Explore the concept of magnetic saturation in inductors
  • Investigate the effects of eddy currents on inductor performance
Electrical engineers, electronics hobbyists, and anyone involved in designing or optimizing inductors and transformers.
amanno
If I wrap a wire around a permanent magnet (iron) to make an inductor... will that increase the strength of the inductance? Or just push the inductor into magnetic saturation?
What if I just use a solid ferromagnetic core (not magnetized) such as an iron or steel rod? How much does that increase inductance over an air coil inductor?
Thanks for the help!
hi amanno,
welcome to PF :)
Reading your post, I am still trying to decide if you have a bit of a misunderstanding about an iron cored inductor
I can't think of any example in any electronics I have ever worked on where the iron core is already a permanent magnet. I can't think of any good reason why you would want to do that. As the magnetic field would work against the the magnetic field being generated by the coil when a current passes through it.
Inductors come in 2 usual styles ...
1) -- air core and a
2) -- ferromagnetic core (not magnetized) it can be either laminated or a ferrite powder as is commonly used in transformers or solid iron core as usually used in an electromagnet for say a relay or solenoid
using a ferrite, laminated or solid iron core has the effect of concentrating the magnetic field within the core and coil. The iron type core can increase the inductance by a factor of 1000 or more over an air cored inductor
Laminated or ferrite / fericeramic cored materials are used to decrease ot stop the generation of eddy currents within the core.
cheers
Dave
9K
  • · Replies 51 ·
