| New Reply |
angular momentum |
Share Thread |
| Aug16-12, 07:52 AM | #1 |
angular momentum
a classical electron moves in a circle of radius 0.5mm with velocity 20ms-1 what is the value of the quantum number L which gives a quantised angular momentum close to the angular momentum of this classical electron? 2. Relevant equations L=r * p 3. The attempt at a solution L=r*p 500e-6 * 20=0.010 |
| Aug16-12, 08:29 AM | #2 |
You need to throw in the equation for quantum angular momentum.
| Aug16-12, 08:36 AM | #3 |
is it L=[itex]\sqrt{l(l+1)hbar}[/itex]
| Aug16-12, 09:03 AM | #4 |
angular momentum
is it possible to find the value of the quantum number "l" (azimuthal quantum number)?
| Aug16-12, 09:09 AM | #5 |
Check the dimensions in that formula.
| Aug16-12, 09:16 AM | #6 |
do i have to presume that n=1 before i continue the calculation, because there is no mention of principal quantum number in the question?
| Aug16-12, 09:55 AM | #7 |
The description says "classical electron". So I guess you should use Bohr's model here. What is the angular momentum in Bohr's model?
| Aug16-12, 10:22 AM | #8 |
the lowest value for n is 1, this gives the smallest orbital radius 0.0529nm(bohr radius)
L=r*p=mvr m=9.1e-31, v=20m/s r=0.5nm mvr=nhbar L=n h/2pi=nhbar |
| Aug16-12, 10:36 AM | #9 |
I think you should use the latter formula to determine n that gives the closest match of L to that of the classical electron.
| Aug16-12, 10:39 AM | #10 |
can you explain that again please
| Aug16-12, 10:52 AM | #11 |
You can compute the angular momentum from the radius and velocity given.
You have the formula for the angular momentum in Bohr's model. What n gives the closest fit between the two? You could also consider the other formula, involving the square root of l(l + 1). For large n, and correspondingly large l, what can be said about the results given by these two equations? |
| New Reply |
Similar discussions for: angular momentum
| Angular momentum of rigid bodies,When to add (moment of inertia*angular velociy) | Introductory Physics Homework | 0 | ||
| Conserved angular momentum: finding angular velocities of drums as a function of time | Introductory Physics Homework | 2 | ||
| Angular Momentum - Find angular velocity of a hanging bar after a collision | Introductory Physics Homework | 1 | ||
| Physics Rotating Disk, Moment of Inertia, Angular Momentum, Angular Velocity | Introductory Physics Homework | 12 | ||
| Angular momentum and orbital angular momentum problems | Introductory Physics Homework | 3 | ||
