What Was the Rocket's Initial Velocity?
  • Thread starter Thread starter Demise
    Altitude
The initial velocity of the rocket launched by Homer Hickim and his friends was calculated to be approximately 622.68 feet per second. This was determined using the equation s = 1/2at^2 + vt, where the acceleration due to gravity (a) is -32 ft/s², the total time in the air (t) is 28 seconds, and the altitude (s) at impact is 15867 feet. The horizontal distance traveled was 3 miles, equivalent to 15867 feet, which was crucial in solving for the initial velocity.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with units of measurement (feet, seconds)
  • Basic algebra skills for solving equations
  • Study the derivation and applications of kinematic equations in projectile motion
  • Learn how to calculate horizontal and vertical components of velocity
  • Explore the Pythagorean theorem in the context of vector addition
  • Investigate real-world applications of projectile motion in engineering and physics
Students studying physics, educators teaching kinematics, engineers involved in trajectory analysis, and anyone interested in the principles of motion and velocity calculations.
Demise
Here is the problem:
Homer Hickim and his friends shoot off a rocket. A fire is reported 3 miles away from the launch pad (1mile = 5289 feet). Homer and his friends are accused of the fire.
Homer knows that the rocket took 14 seconds to come down from its highest point. This means that the rocket was in the air for about 28 seconds before it hit the ground. Use the following equation from the movie to find out the initial velocity of the rocket in feet per second.
s = 1/2at^2 + vt
a= -32
t= time in seconds
s= altitude in feet
v= initial velocity
14x5280 = 1/2(-32)(28)^2+v(28) <--- this is what i came up with for my equation... I am not sure wether the value of S is right, s=alititude how would i find altitude for this problem?
Didn't you already have a thread going with this same problem? https://www.physicsforums.com/showthread.php?t=62879
In any case, find the horizontal and vertical components of the initial velocity separately:
Horizontal velocity is constant; use: speed = (horizontal distance)/time.
Vertical direction is accelerated motion: use: [itex]v_f = v_i + at[/itex] (Hint: what's the speed at the top of the motion?) To me, that's the easiest way to find the vertical component of the initial velocity, but you could certainly use the equation "s = 1/2at^2 + vt": just realize that when t = 28 seconds, s = 0 (it comes back down to earth).
Once you find the horizontal and vertical components of the initial velocity, find the total velocity using the Pythagorean theorem.
To solve Homer's altitude problem, we can use the following equation:
s = 1/2at^2 + vt
Where:
a = acceleration due to gravity, which is -32 ft/s^2
t = time in seconds, which is 28 seconds
s = altitude in feet, which we need to find
v = initial velocity in feet per second, which is what we are looking for
We can plug in the given values and solve for v:
s = 1/2(-32)(28)^2 + v(28)
s = -1568 + 28v
Now, we know that the fire was reported 3 miles away from the launch pad, which is equivalent to 15867 feet. This means that the altitude of the rocket was 15867 feet when it hit the ground. So, we can set s = 15867 and solve for v:
15867 = -1568 + 28v
28v = 17435
v = 622.68 ft/s
Therefore, the initial velocity of the rocket was approximately 622.68 feet per second. This information can be used to determine if Homer and his friends are responsible for the fire, as they can calculate the trajectory of the rocket and see if it matches with the location of the fire.
  • · Replies 30 ·
  • · Replies 16 ·
9K
25K
