Applications of Linear Systems: Electrical Networks
The discussion revolves around analyzing a Wheatstone bridge circuit to determine the current through a specific resistor using linear systems. Participants are exploring the application of electrical network principles, particularly focusing on Kirchhoff's laws and circuit simplification techniques.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the need to apply Kirchhoff's laws and consider alternative methods such as star-triangle transformations. There is also a focus on the importance of correctly defining current directions and the implications of those choices on the final results.
Some guidance has been provided regarding the use of Kirchhoff's laws and the importance of labeling currents. Participants are actively engaging in refining their understanding of the circuit and exploring different approaches, although no consensus has been reached on a single method.
There is mention of the professor's unclear explanations and the participants' varying levels of understanding regarding current, voltage, and resistance. The discussion reflects uncertainty about the implications of choosing current directions and the need for clarity in circuit representation.
adc85
Hey,
How do I find the current through the central resistor (the one that is 1 ohm) in this Wheatstone bridge attached to this post? What approach do I need to take here if I were to solve this using linear systems? Our professor poorly explained how electrical networks work. I can solve the linear system once I get it but I just need to figure out what I'm supposed to do in order to find those equations. Thanks.
Try and redraw the circuit, but simplified so it's easier to see all the "routes" the current can go through. That really helps. :smile:
Another way, without using the Kirchoff's laws, would consist of using the star-triangle transformations and compute in this way the electric potentials at the ends of the central resistor using only the Ohm's laws.
See that's the thing, he never drew any arrows in the problem. I think he said something like we can make up our own directions but I really couldn't understand him. Would the final answer be the same no matter what the directions were?
You can choose your own direction. If you have chosen your arrow in the 'wrong' direction, final answer will reflact that. In other words, you will get a negative result.
OK here's a revised drawing of the diagram. I labeled the direction of the current this time. Are these directions fine? I know next to nothing about how current, voltage, and resistance work.
Now mark the currents with some notations, say I, i, [tex]i_1[/tex].
Say the current through the battory is I.
So at the [tex]2 \Omega, 3\Omega[/tex] junction (left side in your recent picture) , let the current through [tex]3\Omega[/tex] is i and current through [tex]2\Omega[/tex] is I-i (Point rule).
Do similarly at the 3,1,2 junction (top), assuming the current through [tex]1\Omega[/tex] is [tex]i_1[/tex]. Complete the current flow diagram by writing the currents through the other resistors. Don't introduce any other variables.
You need only three variables namely I, i, [tex]i_1[/tex]. Apply Kirchoff's laws to get three equations to solve.
Some one will be along with you if there is another easy way to do this.
regards,
  • · Replies 28 ·
  • · Replies 98 ·
