Does Copper Nitrate React with Water?
  • Thread starter Thread starter ktpr2
    Copper Water
The discussion revolves around the reaction of Copper(I) Nitrate with water, specifically whether it yields Copper(II) Nitrate and how the resulting compounds are structured. Participants explore the chemical balance of the reaction and the nature of the resulting complex.
  • Some participants question whether Copper(I) Nitrate reacts with water to form Copper(II) Nitrate and how the charges balance in the reaction.
  • There is a suggestion that the product could be a Copper(II) hexaquo complex, represented as Cu(H2O)6^2+.
  • One participant expresses confusion about the presence of Copper(I) in the problem and whether a redox reaction is involved.
  • Another participant emphasizes that Copper(I) must be balanced with the negative charge of the nitrate ion, leading to a discussion about the necessity of Copper(II) for charge neutrality.
  • There are multiple references to the balancing of the chemical equation, with some participants attempting to clarify the stoichiometry involved.
  • One participant expresses uncertainty about the type of bonds formed in the compounds and admits to a lack of knowledge on the subject.
Participants do not reach a consensus on whether Copper(I) or Copper(II) is the correct species involved in the reaction, and there are competing views on the nature of the resulting products and their bonding characteristics.
There are unresolved questions regarding the charge balance and the specific nature of the chemical bonds in the resulting compounds. The discussion reflects varying levels of understanding and assumptions about the chemistry involved.
ktpr2
Does Copper(I) Nitrate plus water { Cu(NO)3)2 (aq) + H20 } yeild Cu(NO3)2 3H20? (unbalanced)
From what I've been told, it could equal Cu(H2O)6^+2(aq) but I don't see the NO3 anywhere.
Chemistry news on Phys.org
Do you see anything devious in the underlined part...?
What is that...??
Daniel.
Devious? Uh, Copper(I) has a positive charge, the anion NO3 has a negative charge; so it really must be Copper(II), to balance the molecule. Okay. Now you add water, h2o so all these elements have to show up on the product side. Since Cu(NO3)2 is balanced I have to ask myself if 3H2O is balanced. H is +, so 6+ goes with O which is 2-, 6-. So it looks pretty balanced.
I'll read ahead here. Water is is an extremely weak electrolyte. And ions dissolve in water well so it looks possible. What am I missing here?
How would the chemical bonds be realized in
[tex]Cu_{2}(NO_{3})_{2}[/tex]
compared to the regular
[tex]CuNO_{3}[/tex]
Daniel.
Metal+nonmetal = ion; must be charge neutral
[tex]Cu_{2}(NO_{3})_{2}; (NO_{3})_{2}[/tex] has charge of -1, so that's -2 overall, and since we have two atoms of Cu, it must be normal copper with a charge of -1.
I'm not sure "how the bond would be realized"; by charge forces :)?
BETWEEN WHOM??[itex]CuNO_{3}[/itex] is ELECTRICALLY NEUTRAL... :wink:
Daniel.
I guess it would have be a molecular bond of some kind. I profess ignorance as I'm just reading ahead for class.
I strongly doubt it.I would advise you to use the Cu(I) nitrate,viz.[itex]CuNO_{3}[/itex] :smile:
Daniel.
okay wait I don't have a choice of what kind of copper nitrate I can use. [tex]Cu(NO_3)_2_(aq_) + H_2O[/tex] is all i get. I just wanted to know what kind of product it would make. Thanks for your elucidation though
Well [itex]Cu(NO_{3})_{2} \ _{aq.}[/itex] would mean Cu (II),right...?And why would the problem speak about Cu(I)??Is there some redox that i cannot/don't see? :confused:
Daniel.
The complex you get is the copper (II) hexaquo complex.
[tex]Cu(NO_3)_2 + 6H_2O \longrightarrow Cu(H_2O)_6^{2+} + 2NO_3^-[/tex]
Thanks,Gokul.I knew a clear mind would settle it. :wink:
So it was Copper (II) all the time... :rolleyes:
Daniel.
10K
