Projectile Motion initial velocity
The discussion revolves around a problem in projectile motion, specifically focusing on determining the components of initial velocity given a magnitude and direction. The initial velocity is stated to be 12.0 m/s at an angle of 60.0 degrees above the negative x-axis.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss how to calculate the x and y components of the velocity using trigonometric functions. There is an exploration of the correct application of sine and cosine based on the orientation of the angle.
Some participants have provided guidance on the correct trigonometric functions to use for calculating the components. There is an acknowledgment of a mistake in labeling the triangle, and the conversation reflects an ongoing clarification of the approach rather than a resolution.
Participants are working within the constraints of the problem as posed, with an emphasis on understanding the correct application of trigonometric principles in the context of projectile motion.
ProBasket
Consider a particle with initial velocity [tex]v[/tex] that has magnitude 12.0m/s and is directed 60.0 degrees above the negative x axis.
1.) What is the x component [tex]v_x[/tex] of [tex]v[/tex](velocity)?
Express your answer in meters per second.
a.) [tex]v_x = ____[/tex]
well i drew the picture where the negative x-axis was located, and did sin(60)*12 = 10.392, but since it's where the negative x-axis is, it'll be -10.392 right?
2.) What is the y component [tex]v_y[/tex] of [tex]v[/tex](velocity)?
a.) [tex]v_y = ____[/tex]
well i kinda did the same thing as for the first question, cos(60)*12 = 6m/s
are these two correct?
With the angles reversed,they are... :wink: Pay attention at that triangle...
Daniel.
what do you mean by reversing the angles? so instead of 60, you mean i should use -60?
No,no.The "x" component needs to be gotten with a cosine and the "y" with a sine...Basically just reverse of what u did...
Daniel.
ah thanks for the help, i had my triangle label incorrectly by mistake
  • · Replies 53 ·
