Expansion of space: Earth - Moon
The discussion revolves around the expansion of space and its effects on the Earth-Moon system, particularly in relation to Hubble's law and gravitational influences. Participants explore the implications of cosmic expansion on local scales, including the Moon's recession and hypothetical scenarios like the "Big Rip."
  • One participant presents a calculation using Hubble's law to estimate the Moon's recession rate, questioning its validity and the role of Earth's gravity.
  • Another participant asserts that Hubble's law is not applicable to local systems like the Earth-Moon distance, emphasizing the dominance of gravitational forces over cosmic expansion at such scales.
  • There is a discussion on how to calculate cosmic expansion locally, with some suggesting that gravity keeps local systems intact against expansion effects.
  • One participant mentions that the Moon is indeed receding from Earth due to tidal friction, providing a specific measurement of this rate.
  • Concerns are raised about the "Big Rip" scenario, with some participants expressing skepticism about its likelihood and questioning the evidence supporting it.
  • A reference is made to a paper discussing the minimal effects of cosmological expansion on local systems, noting that changes in the Earth's orbital radius are extremely small.
Participants generally disagree on the applicability of Hubble's law to local systems and the significance of cosmic expansion at such scales. There is no consensus on the likelihood of the "Big Rip" scenario, with some viewing it as speculative.
Limitations include the assumptions about the applicability of Hubble's law and the definitions of "local" versus "cosmic" scales. The discussion also highlights unresolved questions regarding the influence of gravity on cosmic expansion.
Michel_vdg
Hi,
I made a (rough) calculation of how far the Moon would be moving away from Earth according to Hubble's law = 72.6 (km/s)/Mpc
1 megaParsec = 3.08 × 1022 m ≈ 4 × 1022 m
Distance between Moon and Earth ≈ 4 x 108 m
Expansion rate ≈ 7.2 104 (m/s)/4 × 1022 m = 7.2 (m/s)/4 × 1018 m
Thus expansion for Earth - Moon ≈ 7.2 x 10-10 m/s
Is this calculation correct? If so, than that it would be about one picometer per second, or is Earth's gravity force simply keeping the Moon in it place?
Thanks,
m.
Astronomy news on Phys.org
Hubble's law applies to intergalactic distances. It does not apply to stars within our own galaxy, much less distance between planets in a single solar system not distance between a planet and it moons.
ok, thanks.
Than how can we calculate the expansion of the Universe on a local scale, or is there no expansion locally because gravity keeps it all together?
Correct. Gravitational bound objects are essentially immune to the effects of expansion. The force of expansion is overwhelmed by gravity over 'short' distances. By 'short' distances we are talking the level of galactic clusters.
FWIW, the Moon *is* receding, but due tidal friction, currently ~ 38 mm / yr.
http://en.wikipedia.org/wiki/Orbit_of_the_Moon
IIRC, this is measured by laser ranging using the retro-reflector panels positioned by Apollo astronauts or mounted on Russian rover.
Why do I keep hearing that the expansion of space will eventually rip even atoms apart, if it's too weak to affect anything below intergalactic distances?
The so-called "Big Rip" scenario that you describe is hypothetical and not widely believed to be likely. There is no evidence for it, just speculation.
I SEEM to recall (sorry I can't give a link, so this is hearsay) that it has even been disproven, but that may be a stretch. Call it unlikely.
The influence of the cosmological expansion on local systems
F. I. Cooperstock, V. Faraoni, D. N. Vollick
http://arxiv.org/abs/astro-ph/9803097v1
They calculate this kind of thing. The effect is extremely small. The predicted general-relativistic effect on the radius of the Earth's orbit since the time of the dinosaurs is calculated to be about as big as the diameter of an atomic nucleus.
Here's an interesting blogpost by a theoretical astrophysicist on this topic, and somewhere on it there is also a link to that paper:
http://astrokatie.blogspot.co.uk/2012/07/you-dont-have-to-blow-up-universe-to-be.html
Thanks, this was the kind of information I was curious about.
