A few general Qs about momentum and springs.
The discussion revolves around the concepts of momentum and springs, specifically exploring the relationship between force, momentum, and mass, as well as equations related to spring mechanics. Participants are examining both theoretical aspects and practical applications, including problems involving variable mass systems.
  • Homework-related
  • One participant questions the implications of the equation f = m(dv/dt) + v(dm/dt), expressing confusion about the dependency of mass on velocity and vice versa.
  • Another participant cites a textbook definition of the relationship between force and momentum, reiterating that F(net) = dp/dt.
  • Several equations related to spring mechanics are shared, including work done by springs and kinetic energy equations, with one participant providing specific formulas for calculating work associated with spring forces.
  • A participant discusses the application of the chain rule in deriving the momentum equation, particularly in scenarios where mass is not constant, leading to the full form of Newton's second law.
  • One participant raises a question about determining the period of a spring system, hinting at the involvement of cosine functions.
  • Another participant presents a problem involving a car losing mass while a constant force is applied, expressing confusion about how to handle the changing variables in the context of momentum and force.
  • A later reply attempts to manipulate the equations further, suggesting a method to express force in terms of changing mass and velocity, but acknowledges the complexity of the relationships involved.
Participants express varying levels of understanding and confusion regarding the implications of the equations discussed, particularly in relation to variable mass systems. There is no consensus on the best approach to resolve the complexities presented.
Participants note the challenges of applying traditional equations when mass is not constant, leading to unresolved questions about the mathematical treatment of these scenarios. The discussion includes assumptions about the constancy of certain variables and the applicability of specific equations.
merper
if p is momentum then dp/dt = f right?
I've heard that dp/dt can be written as f = m(dv/dt) + v(dm/dt)
Can someone tell me what this actually means, because it would seem that m would be dependent on v and v dependent on m, so I am not sure how this would work out.
Also, can someone point tell me some important equations for springs other than f= -kx and e = .5kx^2
"The time rate of change of the momentum of a particle is equal to the net force acting on the particle and is in the direction of that force" (quoted from Halliday, Resnick, Walker. "The Fundamentals of Physics", 6th ed. 2001)
That is what they used to explain F(net)= dp/dt
As far as, f = m(dv/dt) + v(dm/dt), I'm not sure.
Somemore spring equations for ya:
Work = (1/2)k*(x(initial)^2)-(1/2)k*(x(final)^2)
Work = (1/2)k*(x^2) (work by a spring force with (x initial being 0))
You can use work equations from above to solve different problems associated with energy in the system:
K(final) - K(initial) = Work (k = (1/2)m*(v^2), of course
Hope this helps.
I hope that the following will help you.
You have the equation f=dp/dt, but we know that p=mv so: f=d(mv)/dt.
When m is constant then we have the famous f=mdv/dt we were using at school for years (a=dv/dt), but what happened when m is not constant. When m is not constant the derivative d(mv)/dt is equal to: f=m(dv/dt)+(dm/dt)v which is the full type of the second law of Newton.
For the springs, how does one determine the period. Is there not a cosW somewhere?
alright, i can see how u get the mv equation as a result of the chain rule, but I'm still not sure exactly how it applies. Here's one of the examples my TA used to try and explain this.
A constant Force, F, is applied to a car with mass M containing within, some sand with mass m. (so mass total is M+m at the start). Concurrently, a hole opens up at the bottom of the car and it starts dropping sand at a rate of dm/dt. Find the speed of the car when all the sand is dropped.
So basically we have F = dm/dt(which we know)v + m(dv/dt)
he also pointed out that Pf - P0 = F (delta)t
and that F =m(dv/dt)
So (delta)t = m/(dm/dt)
After this part i got confused - if dv/dt is changing based on mass and v is changing based on dv/dt, how can I do this. Is this a double integral?
Hi!
We have so far that F=m(dv/dt)+v(dm/dt) now multiply the last equation with dt (I know the mathematicians will loose their hair with this but as you know this work very well in physics) and you will get:
Fdt=mdv+vdm and here is where you have the problem, divide with dm and you certainly will fell better when you see that:
F(dt/dm)=m(dv/dm)+v . We know that dm/dt is constant so we can write dm/dt=-c (the - is because the mass of the sand is reducing). So we have:
–F/c=m(dv/dm)+v and -(F/c+v)dm=mdv.
I hope this will help.
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 47 ·
  • · Replies 43 ·
  • · Replies 27 ·
