New Reply
Logarithmic Decay of Hypochlorite/Chlorine by UV light
Share Thread Thread Tools
Aug18-12, 10:26 PM   #1
Hi,
Does anyone know why the decay of hypochlorite/free chlorine in pool water due to UV light might show a logarithmic decay (natural log) as opposed to an exponential one?
I did a chemistry experiment with scaled up concentrations of chlorine and cyanuric acid (scaled up 25x). Even in the solution with no cyanuric acid it still shows logarithmic decay.
Analysis was by titration. Excess potassium iodide and sulpuric acid was added and then it was titrated with sodium thiosulphate.
I'm wondering because ALL secondary data I have found shows a logarithmic decay.
With thanks,
Jaamae.
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Attacking MRSA with metals from antibacterial clays
>> Femtosecond 'snapshots' reveal a dramatic bond tightening in photo-excited gold complexes
>> Beautiful 'flowers' self-assemble in a beaker
Aug19-12, 02:29 AM   #2
Admin
Please elaborate on how did you get to the conclusion it is logarithmic.
Aug19-12, 05:02 AM   #3
I plotted the results as a graph in Excel and the logarithmic trendline option fits best.
Thanks,
Jaamae.
Aug19-12, 05:31 AM   #4
Admin
On how many points of data?
And what have you plotted against what? If [itex]C=C_0e^{-kt}[/itex] you will get a perfect linear plot for [itex]\ln{C}=\ln{C_0}-kt[/itex], but it doesn't mean trend is logarithmic.
Aug19-12, 06:11 AM   #5
Hi,
I plotted amount of thiosulfate added (which is directly proportional to concentration of chlorine left) (y axis) against time (x axis).
I have attached the data. Sheet 1 shows the data with a logarithmic trendline fitted to it. Sheet 2 shows the same data with exponential trendlines fitted to it.
As you can see the R^2 values for logarithmic are much better.
With thanks,
Jaamae.
Aug19-12, 06:13 AM   #6
Woops forgot to attach :)
Aug19-12, 06:36 AM   #7
Admin
I have a feeling errors are way too large for any meaningful result.
Aug19-12, 06:39 AM   #8
OK, but can you think of any reason a logarithmic trendline fits better?
Aug19-12, 06:51 AM   #9
Admin
By pure chance.
Aug19-12, 06:56 AM   #10
But it fits noticably better on most of them. If we take out 1500 and 2500 (procedural anomalies) then its definitely fits better. I have a feeling there is a reason buried in the chemistry somewhere.
Aug19-12, 10:17 PM   #11
Since exponential and logarithmic curves are inverses of each other.
Is it possible that you have exponential decay but your titration would be a
logarithmic curve ?
You can check this with: dm/dt = - km
with solution y(t) = y0e-kt
Solve for k : 1/[Chlorine] = ekt
And data check decay curve
Aug20-12, 02:37 AM   #12
Hi Morrobay,
Thanks for your reply. But could you please explain the bit about a logarithmic titration a bit more. Also what does 'm' represent in your equations?
Thanks very much,
Jaamae.
Aug20-12, 03:37 AM   #13
Quote by jaamae View Post
Hi Morrobay,
Thanks very much,
Jaamae.
m = [chlorine]
see these pages : http://www.physicsforums.com/showthread.php?t=291766
note: I had a question mark on whether the titration curve could be logarithmic.
Maybe you should plot this experiment from a decay curve, see reference
Aug21-12, 03:01 AM   #14
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
How did you expose your sample to UV radiation? Describe the reaction setup.
Did you calculate the quantum yield for Cl2 vs. concentration? The quantum yield can vary from 2 to 4.5 for concentrations of 500 ppm and 1500 ppm respectively. Quantum yield of concentrations less than 100 ppm are ~1.0
Aug21-12, 05:53 AM   #15
Hi,
Firstly thanks very much for your reply. The setup was a commercial UV light mounted above a shelf. The beakers (with different trials in them) were placed under it for 3 hours. Ever 30 mins a 20mL sample was removed and titrated to find the hypochlorite content.
How does one calculate quantum yield? Keep in mind the varying ppm in the excel data is the Cyanuric Acid, which was a test variable. The original chlorine solution was made to be 100ppm. Please elaborate on how to calculate the quantum yield as I am very interested. Thanks very much for your help.
Jaamae.
Aug21-12, 11:34 PM   #16
Other Sciences 2012
Recognitions:
It is described in this paper.
Aug22-12, 04:47 AM   #17
Quote by chemisttree View Post
So is it correct to conclude that this photolysis is exponential decay:
-d[A]/dt = k[A] and as Borek said in post #4 it is linearized to :
ln [A]t = ln [A]0 -kt
New Reply
Tags
analysis, chemistry, chlorine, decay, logarithmic
Thread Tools
Similar Threads for: Logarithmic Decay of Hypochlorite/Chlorine by UV light
Thread Forum Replies
understand the two doubly degenerate mode of D4h symmetry Chemistry 2
Weight percent of hypochlorite in bleach Biology, Chemistry & Other Homework 4
neutralize chlorine in hot tub Chemistry 1
hypochlorite and thiosulfate Biology, Chemistry & Other Homework 0
10,000ppm hypochlorite Chemistry 5
