What is the density of free electrons in the metal?
The density of free electrons in a metallic wire with a diameter of 4.12 mm and a current of 8 A is calculated to be approximately 1.46 x 1029 electrons/m3. This calculation utilizes the formula n = I/(qAv), where n is the density of free electrons, I is the current, q is the charge of an electron, A is the cross-sectional area, and v is the drift velocity. The cross-sectional area is derived from the diameter, and the drift velocity is given as 5.4 x 10-5 m/s. The charge of an electron is incorporated into the calculations to arrive at the final density value.
  • Understanding of electric current and drift velocity
  • Familiarity with the formula n = I/(qAv)
  • Knowledge of the charge of an electron (approximately 1.6 x 10-19 C)
  • Ability to calculate the cross-sectional area of a wire from its diameter
  • Learn how to calculate the cross-sectional area of different wire shapes
  • Study the relationship between current, charge, and drift velocity in conductors
  • Explore the implications of electron density on electrical conductivity
  • Investigate the effects of temperature on the density of free electrons in metals
Students and professionals in physics, electrical engineering, and materials science who are interested in understanding electron behavior in conductive materials.
kyang002
A metallic wire has a diameter of 4.12 mm. When the current in the wire is 8 A, the drift velocity is 5.4*10^-5 m/s.
I have considered a wire of cross-sectional area A, with current I. V is the drift velocity of the free charges in the conductor and n is the number of charged particles per unit volume. Then the current is given by I = nqva, where q is the magnitude of the charge on a charge carrier.
I = 8
n = density??
A = (2.06)^2 * 3.14
v = 5.4 x 10^-5
q = ??
Can someone help me out on the answer for this problem? Thanks!
Pay attention with the units...
HINT:
[tex]|\vec{j}|=\frac{I}{S}= n |q_{el.}| |\vec{v}_{drift}|[/tex]
Daniel.
The density of free electrons in a metal can be calculated using the formula n = I/(qAv), where I is the current, q is the magnitude of the charge on a charge carrier, A is the cross-sectional area of the wire, and v is the drift velocity of the free electrons.
Based on the given information, we can plug in the values and solve for n:
n = (8 A)/(q * (4.12 mm)^2 * π * (5.4 x 10^-5 m/s))
To solve for q, we can use the known relationship between current and drift velocity: I = nev, where e is the charge of an electron.
Rearranging this equation, we get q = I/(nev). Plugging in the given values, we get:
q = (8 A)/(n * (5.4 x 10^-5 m/s))
Now we can substitute this value for q into our original equation for n:
n = (8 A)/((8 A)/(n * (5.4 x 10^-5 m/s)) * (4.12 mm)^2 * π * (5.4 x 10^-5 m/s))
Simplifying, we get:
n = 1.46 x 10^29 electrons/m^3
Therefore, the density of free electrons in the metal is approximately 1.46 x 10^29 electrons per cubic meter.
9K
22K
  • · Replies 23 ·
