Drawing Lewis Dot Diagrams: Rules Beyond the Octet Rule
The discussion revolves around the rules for drawing Lewis dot diagrams, particularly focusing on the limitations of the octet rule and the specific case of glucose (C6H12O6). Participants explore the conditions under which atoms achieve stable electron configurations and the implications for molecular structure.
  • One participant questions the rules for drawing Lewis diagrams beyond the octet rule, specifically in the context of glucose.
  • Another participant asserts that the oxygen atoms in the proposed structure do not have octets, as they are assigned four bonds, which contradicts typical bonding rules for oxygen.
  • A different viewpoint argues that the oxygens do achieve octets through a combination of double bonds with carbon and single bonds with hydrogen.
  • One participant emphasizes that in organic compounds, oxygen typically has an octet, challenging the previous assertion about oxygen's bonding capacity.
  • There is a suggestion that the main issue with the proposed structure may not be the oxygens, but rather the overall bonding configuration that fails to satisfy octet requirements.
  • Participants discuss the necessity of knowing valence electrons and the requirement for atoms to achieve a valence octet, with one stating these are the primary rules for most organic compounds.
Participants express disagreement regarding the bonding capabilities of oxygen and whether the proposed structure of glucose is feasible. There is no consensus on the correct interpretation of the bonding rules or the validity of the proposed Lewis structure.
Participants highlight the importance of understanding valence electrons and octet fulfillment, but there are unresolved aspects regarding the specific bonding configurations and the implications for molecular stability.
This discussion may be useful for students and individuals interested in organic chemistry, particularly those learning about Lewis structures and the rules governing electron configurations in molecular bonding.
bomba923
What are the rules for drawing Lewis dot diagrams, besides the
1) Carbon usually has a full octet
2) Some atoms become electron deficient, others electron sufficient
3) The Duet Rule
4) Link OH if written in the formula
What the "other" rules?
For example, i try to draw glucose, C6H12O6:
*I make a hexagon of six single-bonded carbon
*I attached a double-bond with oxygen to each carbon (carbon has 2 single bonds, and one double bond, so it obeys octet rule)
*I finally attach two single-bonded hydrogen to each oxygen.
Why doesn't this work? I have six carbon with octets, six double-bonded oxygen=carbon bonds (six oxygen), and two hydrogen at each oxygen
C-C-C-C-C-C with C=O, where each oxygen then bonds with two hydrogen
Why is this incorrect----what are the other rules for drawing lewis diagrams??
Chemistry news on Phys.org
In this case, your oxygen atoms do not have octets. That is the main problem. Typically, for oxygen to have a neutral octet, it can support only 2 bonds (either one double-bond or two single bonds), but you are trying to give it 4 each.
In any case, expecting you to guess the structure of glucose by trial and error is quite unreasonable. It could take forever, and there's no good reason to make you try the gazillion possibilities before finding the correct one.
But the oxygens do have an octet--a double bond with the carbon, and two single bonds with hydrogen (one double bond+2 single bonds gives 8 electrons, doesn't it?)
Oxygen can have only "two" bonds for a neutral octet?
If so, these are the kind of rules I should know about; are there more such rules?
Just for the record,Gokul,in any ORGANICAL COMPOUND THE OXYGEN HAS AN OCTET...Your assertion was made on an erroneous basis provided by the OP...
Daniel.
So then, the oxygens aren't the problem? Then what is?
They do indeed.They have either double bond with the C or 2 simple bonds,1 with the C and one with the H.In this case...
Daniel.
P.S.Glucosis does not have a cyclic structure... :wink:
I know this Dexter. I was explaining to Bomba why his structure was infeasible.
No, the oxygens are the problem. The only way to ensure an octet as well as the correct charge for oxygen is through 2 bonds and two unbonded pairs. With 4 bonds, you make an octet, but you only have 4 electrons contributed by O, whereas you need 6.
Well then :smile: ...are there any other such rules I should know about?
Just curious, what are the other general rules?
1. Know the number of valence electrons in different elements (O=6, C=4, N=5, H=1, Cl=7, etc.)
2. After sharing electrons all atoms must have a valence octet (except H, which gets a duet)
Really, these two are the only rules you need to know for most organic compounds.
15K
13K
11K
