Converging Lens Problem: Finding Distance from Slide for Real and Virtual Images
  • Thread starter Thread starter nemzy
    Lens Thin lens
The discussion centers on solving the Converging Lens Problem involving a lens with a focal length of 2.24 cm and an image distance of 11.4 cm. For a real image, the lens is positioned 2.79 cm from the slide, calculated using the thin lens equation 1/p + 1/q = 1/f. For a virtual image, the lens is 1.87 cm from the slide, applying a negative value for the image distance. The error in the initial calculations stemmed from misunderstanding the relationship between the image distance and the slide distance.
  • Understanding of the thin lens equation
  • Knowledge of real and virtual images in optics
  • Familiarity with focal length concepts
  • Basic algebra for solving equations
  • Study the thin lens equation in detail
  • Explore the differences between real and virtual images
  • Learn about the effects of varying focal lengths on image formation
  • Practice additional lens problems involving different configurations
Students studying optics, physics educators, and anyone interested in understanding lens behavior and image formation.
nemzy
A transparent photographic slide is placed in front of a converging lens with a focal length of 2.24 cm. The lens forms an image of the slide 11.4 cm from the slide.
(a) How far is the lens from the slide if the image is real?
(b) How far is the lens from the slide if the image is virtual?
I got the wrong answer, and i don't know why.
This is how i attempted part a:
a) focus=2.24 cm
q= 11.4 cm (positive, since the image is real)
1/p + 1/q = 1/f solve for p
b) i did same process except p = -11.4 cm (negative since virtual image)
But yet still got the wrong answer
What am i doing wrong? thanks
a) focus=2.24 cm
q is not 11.4 cm. q should be the distance of the slide from the lens, and 11.4 cm is said to be the distance between the slide and its image.
ehild
It seems that you have the right approach for solving this problem. However, it is possible that you made a mistake in your calculations. Let's go through the steps together to see where the error might have occurred.
First, we need to identify the given values:
- Focal length (f) = 2.24 cm
- Image distance (q) = 11.4 cm
- Object distance (p) = unknown
Next, we can plug these values into the thin lens equation:
1/p + 1/q = 1/f
Solving for p, we get:
1/p = 1/f - 1/q
1/p = 1/2.24 - 1/11.4
1/p = 0.4464 - 0.0877
1/p = 0.3587
p = 1/0.3587
p = 2.79 cm
Therefore, the lens is 2.79 cm away from the slide if the image is real.
For part b, we can use the same equation but with a negative value for q since the image is virtual:
1/p = 1/f - 1/q
1/p = 1/2.24 - 1/-11.4
1/p = 0.4464 + 0.0877
1/p = 0.5341
p = 1/0.5341
p = 1.87 cm
So, the lens is 1.87 cm away from the slide if the image is virtual.
It's possible that you made a mistake in your calculations or accidentally used the wrong values. Double-check your work and see if you can find where the error occurred. Hopefully, this explanation helps you understand the problem better. Good luck!
